20-50w ?
read up---> http://forums.maxima.org/3rd-generat...iscussion.html
Actually I believe it states on a sticker under the hood that you can use 20w50 pending summer like temps. But 10w30/10w40 is suggested for regular driving conditions...really it depends on the outcome of the oil your using now. If she sounds/runs good on 10w30 and doesn't really burn any oil after 3500 miles of driving then you should stick with 10w30. If your doing heavy driving during summer conditions and you see a high amount of oil consumption then you could try 15w50 or 20w50. I use to use 20w50 during summer in my '91Sentra(230,000 miles) due to bearing noise. After replacing the bearings I went back to regular weight.
Your lifters are not clacking, the noise you are hearing are the VTC assemblies...
I return the 20-50 oil back n got the 10-40. It's work fine in my last oil change. When it starts to clacking again (3 months) I will know then that its time for a oil change. I wish oil would some Joe fix the clacking on the lifters. It's not the vtc
