Blew up my VG finally
Old Aug 4, 2013 | 04:10 PM
akurtzer57's Avatar
So was on way to local 1/8 mile track to run. On highway buddy in his cummins tried to mess with me. Down shifted to second. Instant spin and pulled away then cose to redline felt bad hesitation let off but was to late motor was done. Limped it home 3 miles. Tore down today this what I found. Luckily my heads are still good. Only #4 piston is toast. Block could be save if bored it. So going look into injector see if that was the culprit. Tune was spot on and has been running this much boost for 2k miles and took a serious beating for stock motor. Undecided what I want to put back in it. Only took hour to pull heads
This is everything had to remove for heads. Very little vs a stock motor.
Old Aug 4, 2013 | 08:54 PM
Chris Gregg's Avatar
Get Off My Lawn
Bore. Dished pistons. New turbo ring set. Done.
What was duty cycle on your injectors?
Old Aug 5, 2013 | 06:32 AM
James92SE's Avatar
2 VE's are better than one!
Pics no worky?
Old Aug 5, 2013 | 06:44 AM
Get Off My Lawn
They worked before. I can't see them today though. It was kinda ugly, maybe it's better no one else becomes traumatized?
Old Aug 5, 2013 | 07:13 AM
akurtzer57's Avatar
Strange still have them hosted. Try fix them when I get home. Plan is rebuild another motor I have on stand will keep stock internals. But I will be upgrading fuel rails and injectors with e85. I'll have to look at my logs but 90% sure I maxed my injectors out. They were only 450cc
Old Aug 5, 2013 | 08:46 AM
DanNY's Avatar
Ad·min·is·tra·tor
oh wow...yeah 90% is really rolling the dice with them.
at least you can get into it and build it better.
good luck man
Old Aug 5, 2013 | 09:36 AM
akurtzer57's Avatar
No 90% sure there maxed. I'm going guess duty cycle was over 100%. My 370cc were 116% duty cycle why I had a fmu on top.
Old Aug 5, 2013 | 12:46 PM
DanNY's Avatar
Ad·min·is·tra·tor
wow!!!
Old Aug 5, 2013 | 02:11 PM
akurtzer57's Avatar
Fixed the pictures. Also went through my datalogs only had one log from other day. Was on 12 ish psi and my duty cycle was 79% so definitely what my issue was. Got in a rush that day and should of paid closer attention. Can't believe I maxed out these 450cc aready. Guess build it more this time.
Old Aug 5, 2013 | 06:03 PM
James92SE's Avatar
Wow. So what exactly happened? That injector failed and went insta-lean in that cylinder?
Old Aug 5, 2013 | 06:12 PM
akurtzer57's Avatar
I'm guessing maxed out injectors/stock rail and couldn't keep up. 450cc only good for around 400hp which was my goal. Think I'm way beyond. Found out on 25psi duty cycle was 130-140%
Old Aug 5, 2013 | 06:14 PM
chrome91's Avatar
too much naaaawz
Old Aug 5, 2013 | 06:21 PM
James92SE's Avatar
And your tranny is stock? How did 3rd gear like all that power?
Old Aug 5, 2013 | 06:29 PM
akurtzer57's Avatar
Stock vg trans still shifts like butter
Old Aug 5, 2013 | 11:59 PM
Hectic's Avatar
I'm a little confused about how exceeding the duty cycle of the injectors can cause that. Does it just flood the cylinder to the extreme and lock up?
Old Aug 6, 2013 | 07:05 AM
akurtzer57's Avatar
Opposite of flooding. Running high duty cycle can cause them get hot and burn up. Most likely this what happened or was weak to begin with. That's the risk of running old used injectors. So this cylinder leaned out and caused detonation. Which got hot and melted the piston.
Old Aug 6, 2013 | 08:48 PM
Hectic's Avatar
I don't want to compare to NA, but why doesn't the same thing happen with sputtering or failed injectors? Or maybe it could if you run the engine hard enough..
Old Aug 7, 2013 | 02:58 AM
akurtzer57's Avatar
Usually when side feeds go out not working and not getting any fuel. Something Luke this was getting not near enough plus all the boost make it get very hot .
Old Aug 10, 2013 | 12:37 PM
akurtzer57's Avatar
Got the rest of everything pulled last night. Was very upset when I pulled the clutch off the flywheel. This was a Southbend stage 5 rated at 575 ft lbs torque. Cost me around $600 with the extra for cyro treatment. This is shot also now need new disc for my fidanza flywheel. Also this clutch was only in for around 2k miles. Still has tons of meat left on it just chunks coming off. I never had it slip once.
Here she sits in wheelie mode waiting for a fresh motor.
Old Aug 10, 2013 | 12:53 PM
defiance's Avatar
Good looking car ! Cant wait to see what you going to do with it next !
Old Aug 10, 2013 | 05:34 PM
akurtzer57's Avatar
Wish my neighbor come off one of those rodeo dana 44 rear ends for my Turbo hardbody. LOL theve been sitting over a year.
Old Aug 11, 2013 | 07:23 PM
chrome91's Avatar
i wanted to do that swap when i had my Hardbody, one of the best rear end swaps. you get rear discs with LSD and the Rodeo rear end is almost bolt in
Old Aug 17, 2013 | 08:54 PM
akurtzer57's Avatar
Contacted southbend clutch. Will be getting my clutch rebuilt between $225-275. Was going possibly tear down motor Im building this weekend and getting prep work done and get block to machine shop. Should be pretty cheap to do full rebuild. Plan on having back together under 1k which is not bad. Going OEM rings, clevite bearings, OEM 9:1 pistons, OEM headgaskets and bolts. Basically Another stock bottom end. Soon as find some 850cc will order material to make some custom -6 aluminum fuel rails.
Old Aug 17, 2013 | 09:41 PM
mrkanda's Avatar
Taking my Maxima to the Max!
What's your best guess of HP that you were running and at what psi when it blew?
Old Aug 18, 2013 | 12:05 AM
akurtzer57's Avatar
Hell idk mid 400s maybe
maxima297
Sep 30, 2015 03:32 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
