New TPS
Old Nov 7, 2013 | 03:47 PM
majordan's Avatar
New TPS
Should I get an ohm reading for a new TPS straight out the box? and if so, what should it be?
tks
r/Mark
Old Nov 18, 2013 | 03:26 PM
GluteusMaximus's Avatar
Yes. A TPS is just a potentiometer.
Low ohms with throttle closed and high with it wide open, or vice versa, depending on what kind of mood the engineer was in that day.
The key is the resistance steadily changes as you open and close the throttle, and does not jump around erratically or have opens or dead spots throughout its travel.
An analog ohmmeter is very good for finding problems with pots. The needle should always move steady and smooth. If you see it jump, spike or suddenly fall to zero as you are moving the throttle, replace the TPS.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
