Just how tight should the screws be on the valve covers?
Old Jan 31, 2014 | 01:32 PM
RaptonX's Avatar
The screws were noticable loose when I turned a few of them with a screw driver, the grommets they go into on the valve cover being worn from time and heat, but just how tight should I turn it. I thought they were tightened back in 2007 when they worked on the car, but I guess they did not need to open that part. I did hand tighten them a little, but not much more then that.
1989 Nissan maxima, 93k on it.
Old Jan 31, 2014 | 03:06 PM
chrome91's Avatar
hand tight is enough, dont leave them loose or ream on them
Old Jan 31, 2014 | 03:24 PM
ac max 92's Avatar
Hand tight. I take it that 93,000km? Is that original km or on a JDM engine? If original that sounds like it must be in good shape.
Old Jan 31, 2014 | 06:26 PM
Hectic's Avatar
0.7-2.2 ft-lb
Old Feb 2, 2014 | 05:24 PM
CMax03's Avatar
I would suggest you guys change those Phillips heads screws to hex head bolts and/or use Loc-Tite on your threads to prevent them loosening over time which they will!!! The other benefit is beingable too tighten them even if under the intake manifold.
TKHanson
Nov 24, 2018 01:39 AM
doctorpullit
Mar 29, 2016 11:08 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
sliptap
Sep 30, 2015 05:57 AM
