difference between stock lights and bmw conversion? look.
Old Jan 20, 2002 | 07:01 PM
ngthing's Avatar
the stock output from the 9004s is about 700 lumens on low beam, and 1200 on high beam.
with the bmw conversion, you'll be usuing 9005 and 9006 bulbs, for your low beam, you'll be usuing 9006, that puts out about 1000 lumens, that's 300 more than your stock lights, and only 200 less than your high beams
when you use your high beams, you'll switch on your 9005s, those put out about 1700 lumens. bright.
all these numbers, depending on the quality control of the bulb are +/- 15%.
here's the stats:
9004 - 700/1200
9005 - 1700
9006 - 1000
all numbers +/- 15%
Old Jan 20, 2002 | 07:08 PM
Wink519
Woa
hey nghting, did you put projectors in your high beams as well? I never noticed it before.
Old Jan 20, 2002 | 07:15 PM
ngthing's Avatar
Re: Woa
no, i left the high beam along, putting HIDs in there would defeat the purpose of a high beam. the picture just came out like that.
Old Jan 20, 2002 | 07:17 PM
Wink519
they still look extremely sweet.
Old Jan 20, 2002 | 07:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: difference between stock lights and bmw conversion? look.
can you tell me where are u getting these numbers from? what are the numbers for H4/H3/H1 etc etc
here's the stats:
9004 - 700/1200
9005 - 1700
9006 - 1000
all numbers +/- 15%
Old Jan 20, 2002 | 07:35 PM
ngthing's Avatar
Re: Re: difference between stock lights and bmw conversion? look.
They are from a Osram Sylvania data sheet, I just threw it away..arrg! Give me a bit, maybe I can pull it up.
Old Jan 20, 2002 | 11:56 PM
Bman's Avatar
It's also on the www.sylvania.com website!
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
