help plz
help plz
hellow other members i have a 1992 maxima gxe and the problem is when i drive my car the first 10 mins it runs beautiful then it seems after its get warmed up its runs bad very slow from a stop nd doesent gain speed
new parts
o2 sensor
maf
cat
injectors ive replaced/just had them checked out and every thing is normal....any thing helps thanks
new parts
o2 sensor
maf
cat
Have you tried doing a tune up? ie spark plugs, wires, Cap and rotor for the distributor and air filter? If a good tune up doesn't help you could try swaping the coil below the distributor or tps could be another culprit.
these are the parts ive replaced
02 sensor
maf/new filter
plugs and wires
collant temp sensor
fuel injectors
timeing belt/waterpump/tensioner
and ive check the ecu got code 55 normal operation
its seem to have to do with once the car is warmed up because in the first 10 mins of driven runs like new then once its warmed up it has no acceleration at all even when flooring it.....
im thinking maby ill try replaceing the collant temp sensor pig tail bc its a lil broken the plastic is chiped on it but becides that im going crazyy with this issue
02 sensor
maf/new filter
plugs and wires
collant temp sensor
fuel injectors
Same Problem as You
My GXE is doing the same thing and I want to add that I changed the knock sensor due to code and my coolant temp sensor as well. Also fixed a vacuum leak. Each of those things seemed to help the car for the remainder of that day. Then the next day, back to the same. For the first 10 minutes it runs better as well and then it seems that once the car gets up to Normal Operating Temperature so that the ECU starts taking readings from all the sensors that it feels more like a 4 cylinder. It has to downshift to a passing gear to go from 20 to 35 miles per hour!?!. I chimed in to let the original poster know that I feel his pain and also to share what I have also done to mine and the fix has not been permanent.
Could it be the ignition coil? Could the spark plugs be gapped wrong? Distributor/cap/plugs/wires are not that old for either of us it sounds like. Fuel pressure is good at the filter as well.
Hoping you guys can find something that will help us both. Hang in there my brother.
One more thing...
Meant to also mention that mine was doing this and still passed emissions so I am pretty sure it isn't the cat, MAF, or oxygen sensor we are dealing with or I would have failed. Completely stumped.....to good of a car to have no power.
Interesting to see these VG's exhibit some classic VE-style lack of power head scratchers. Kind of strange I don't recall ever reading about stuff like this on VG's until just the past couple of years.
Usually a good tune up will usually fix most engine lag. You could also try checking and cleaning up the ground points but plugs, wires, air and fuel filter along with a cap and rotor will help bring some life back to it. Again you can also check the throttle body position sensor at the intake manifold and clean up the connections and make sure your wires are down all the way on your plugs and nothing is arcing causing a loss of power as this can also be an issue with hairline cracks on the distributor cap and rotors do wear over time. Remember these cars are over 20 yrs old lol. Strange how this only happens when it's warm and after 10 min. If I remember correctly there is something about loss of power when engine is cool and when warm somewhere in the fsm. Try checking the fsm to see if it can help with your diagnosis.
no power at all its struugles to hit 60mph feel like it went from 160hp to about 30hp
also the exhaust gets louder nd starts to backfire
no trottle respone at all u gota floor it to get it to move
had an 89 vg and had the same issue. ran beautiful when cold but once it warmed up it felt like it cut out on 1 then 2 cylinders. it turned out to be the spark plug wires grounding themselves on the manifold. it was weird idk why the temp would effect the wires.. anyway new wires did the trick
yea see i never had a fsm i just ordered one today so hopefully i can find some info its just so strange how it can run soo perferct in the first 5 to 10 mins then just crap out here some symptoms what happens when its warm
You shouldn't need to replace the distributor itself unless you have a bad bearing but you would probably know it if you did. Just the cap and rotor. It's very simple to do. Good call on the NGK wires and not some cheap ones.
that's what i was thinking too...but he said he replaced it.
only other thing is the coolant temp sensor (ECU one)...or the plug..since they tend to get a little messed u over time.
riggy
Aug 6, 2001 07:35 PM
madmax97
Jul 4, 2001 10:10 PM
madmax97
Mar 28, 2001 08:57 PM
tunedup
Mar 9, 2001 08:00 AM
