obx hearders problems
Old Oct 27, 2014 | 09:40 AM
custommaxi92's Avatar
Hellow guys this for anyone that's has the obx headers I've grinded the flange down bc it wuz tapping in the rack its not hitting as much now..
now around 4000rmp it still hits the rack nd makes my car jump around I wuz woundering what you guys have done or maby I culd adjust motor mounts or anything thanks......I didn't kno about pacesetter headers I would of gotten them
Old Oct 27, 2014 | 11:15 AM
James92SE's Avatar
2 VE's are better than one!
One thing you could do is stiffen your motor mounts so that the engine doesn't move as much. Fill them with urethane.
Old Nov 6, 2014 | 09:52 AM
CMax03's Avatar
I wrapped my rack with exhaust wrap and it was only coming close to it in reverse...I ground the floating flange down to ensure clearance!
Old Nov 7, 2014 | 06:56 PM
You think you could show me a pitchure and did you grind top nd bottom flage or just the header flange
Old Nov 7, 2014 | 08:22 PM
cdoublejj's Avatar
yeah, i'm thinking about OBX headers, all th pics and info would helpful. i already say the threat on cutting the conduit to lengthen the wires with out splicing.
Old Nov 8, 2014 | 08:37 AM
CMax03's Avatar
The rear flange that is located @ the rear header merge you need to grind down the 3-bolt flange to clear the rack....OBX copied the Pacesetter design to the Tee!
The Flange is like this:
You can grind it to look like this on the rack side:
This was to eliminate the exhaust leak between the merging pipes! The 3-bolt flange here is the one you need to grind on one side closest to the rack. Wrap your rack with exhaust wrap as well to keep it cool and dampen the noise if it contacts the rack. I have poly filled engine mounts so my engine is really secure!
Old Nov 9, 2014 | 02:40 PM
rokue's Avatar
Did you add those flex pipes? Also what did you use to grind it?
Old Nov 10, 2014 | 05:29 PM
CMax03's Avatar
Yes, I threw the spring loaded header merge hardware in a hardware bucket and I'm using SS bolts with no springs (shorter) and I secure the merge section not to slip nor rotate at all! Cut out the third ball and socket exhaust joint and installed a small flex section and a rear flex section to allow some movement.....The floating flange can be ground with a die grinder or Dremel!
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
