Wrong MAF?
Old Dec 29, 2014 | 08:06 AM
  #41
Not a mechanic!'s Avatar
Originally Posted by ac max 92
Yes sir. You got the just of it. I'd put some coolant in before starting it up though it will take a little while idling for the car to warm up to temerature. Fill the coolant through the rad slowly and watch until the bubbles are gone out of the bleeder then replace the screw. Once the rad is topped up and there is no bubbling and just a nice swirl your good. I'd leave it idle for a bit once it's warmed up to let the thermostat open up allowing the coolant level to drop in the rad and then slowly top it up then top up the resevoir a little but well below the max mark and you should be good to go . From there just keep an eye on it for a few days and if you have no issues you should be fine.
Got it, done. Now all the dash lights went out. Good grief. I guess I need a project. . Checked the fuses and no dash light designation. Any ideas!?!? and yes, it was 4:00 am when I was working on it.
Old Dec 29, 2014 | 03:52 PM
  #42
ac max 92's Avatar
As long as it's now running like a top who needs dash lights lol just drive it during the day lol. Just kidding. Are the rear brake lights out as well? I'll have to check into it. I can't remember if it runs on that same circuit or not. Have you checked all the interior light related fuses?
Old Dec 31, 2014 | 01:45 AM
  #43
CMax03's Avatar
get a test light and start testing fuses
Old Jan 1, 2015 | 05:31 AM
  #44
Yep, tail lights too. Replaced he fuse and popped it a few more times. Had a box of 10 or 12 10amp fuses. Used 4 before they stopped blowing. Now I've wiggled wires and drove the gravel driveway a few times and it hasn't popped again ...yet. I do have a feeling this isn't over though. Hahaha. Thanks guys...the car is running great!
Old Jan 1, 2015 | 07:25 AM
  #45
ac max 92's Avatar
Atleast you know what circuit it is. Check the wiring diagram and if it does start acting up again sounds like you need to trace it and find the break. Hopefully it's not far from the fuse panel.
Old Jan 1, 2015 | 08:10 AM
  #46
Tiniform's Avatar
Check the sockets in the back lights, license plate included. I've read on here where guys have had problems with corroded sockets resulting in popped fuses. Great job though, you finally got it running right.
TallTom
57
Oct 14, 2025 05:16 PM
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
