maxima won't start when it's been raining
Old Dec 24, 2014 | 04:38 AM
markevans999's Avatar
1994 maxima gxe. 120k miles in excellent condition. over the past year the car sometimes won't start when the weather has been very wet for a couple of days. car turns over, has new battery, but it won't start. if weather clears for a few days car will then start. car is garage kept. car normally has no problem starting when it's dry.
Old Dec 24, 2014 | 05:53 PM
CMax03's Avatar
Spray the inside of your distributor cap with WD40, maybe the moisture/humidity is causing the distributor to sweat
Old Dec 24, 2014 | 08:07 PM
ac max 92's Avatar
Like CMax said. Check the distributor for signs of moisture or even any hairline cracks. Also check your wires. Try doing a tune up if one hasn't been done in awhile. Definately start with cap and rotor, wires and ignition coil under the distributor. Wires could be arcing. Is it cranking strong? What is it doing when your turning the key?
Old Dec 25, 2014 | 05:04 AM
engine cranks strongly, just won't start. battery less than 6 months old. i'll try the dw40. cars always starts on first crank when dry. this only happens when it stays wet for a couple of days.
Old Dec 25, 2014 | 06:57 AM
ac max 92's Avatar
I'd just be careful spraying too much because the rotor causes friction. I'd also definately check for cracks and check or replace the wires.
carguy96
20
Feb 6, 2021 06:21 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
erniel
Aug 8, 2015 09:32 AM
dauntlessmax
Aug 5, 2015 10:29 AM
