Engine questions for those boosted.
#41
You could use a speed bleeder (http://www.speedbleeder.com) to bleed it yourself. They have a one way valve that only allows fluid to flow out and stops bubbles from coming in. You can bleed your clutch line in 5 minutes all by yourself.
#42
Now, I can't exactly tell if ASNU itself redrills/sells injectors, or if ASNU is just the manufacturer/developer of the cleaning and flowtesting equipment. It seems they do both from some web searching. There are ASNU "locations" all over the world now, but the original ASNU appears to be in Canada, which is where mine were flowtested at.
I guess I have no way to determine whether or not "the" ASNU actually was responsible for the drilling of my injectors seen in my picture on page 1. At the very least they flowtested those hideous redrills and effectively stamped their approval on them.
#46
