fog lights
Old Jan 27, 2002 | 04:22 PM
gold4dsc's Avatar
fog lights
if i where to buy after markey lights will it be possible to hook them so so that i could use the stock fog lights switch instead of putting in the new one?
Old Jan 27, 2002 | 04:28 PM
dnas420's Avatar
yes
thats what i did. all you have to do is cut off the factory connector that plugs into the oem fogs and splice them together.
Old Jan 27, 2002 | 04:31 PM
gold4dsc's Avatar
Re: yes
is this something i can do with ease or will it take a while for me to do it and also what do i have to put around the cut wires so they don't get wet and ahort out
Old Jan 27, 2002 | 04:37 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Re: yes
just cut and splice the wires and use connectors(Radio Shack has em) to make a solid connections then use electrical tape to keep it dry and then some wire loom for a little added protection!
Old Jan 27, 2002 | 04:40 PM
gold4dsc's Avatar
Re: Re: Re: yes
ok thanks now i need to figure out which ones to get
Old Jan 27, 2002 | 08:15 PM
PDubs's Avatar
These foglights that you guys spliced into the factory wires, did they come with a relay or does a relay not matter when you use the factory wires?
Old Jan 27, 2002 | 09:10 PM
DA-MAX's Avatar
the factory wirirng should already have a relay, if I'm correct!
Old Jan 27, 2002 | 09:52 PM
FFxI30's Avatar
You will have to purchase a relay at any local auto parts store. If you look under your hood in one of the relay boxes you will see a spot labeled fog lights. You can also buy the factory switch from Nissan for like $10 and this will make your setup inside pretty easy and good looking. I bought some used factory SE fogs and put them on my car, it was so easy, the holes where already drilled, all i had to do was buy the lights and the brackets. If you got anymore questions just shoot me an email.
PJ
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
