Will I rub?
Old Jan 28, 2002 | 08:43 AM
707_Maxima's Avatar
Will I rub?
I'm looking into lowering my 92 SE and i have 17's with 225/45 tires. I wanna get the sprints because they lower it the most but I'm afraid of fender rubbing. will this combo work? Also I need some new shocks at an affordable price, any advice would help, thanks.
Old Jan 28, 2002 | 09:09 AM
3RDGEN's Avatar
Re: Will I rub?
I duno about the rubin, but for a sprint drop you should look into some performance struts like koni. I've got intrax & tockiko's, the ride was crap with stock tires, I installed some 205/40 17's & it rides soo nice now.
Old Jan 28, 2002 | 12:05 PM
snoboarder's Avatar
I got a arospeed lowering job (1.75)(bigger drop than the sprints) And i have 205 45 17 tires now. No rubbing here. So, you'll be ok.
Old Jan 28, 2002 | 12:08 PM
Bman's Avatar
Usually the problem on our cars isn't fender rubbing, but strut/suspension rubbing if the offset on your wheels is too high and the tire too wide (235 seems to be the limit). Lowering with springs shouldn't affect whether it rubs or not since the springs don't change suspension geometry, only range of travel and ride height. Do you get rubbing NOW in hard corners, big road bumps/undulations, full-lock turning, etc, etc? If the answer is NO, then you should be fine.
KYBs are the most affordable "performance" strut but some debate if these are better than the more expensive ones though.
Use the SEARCH function to read more about the different kinds of struts and more opinions on your springs, rubbing, etc. Might take a while, but once you know how to use the search well (picking key words is helpful) you almost won't have to ask anything!
Old Jan 28, 2002 | 01:31 PM
707_Maxima's Avatar
I thought sprint lowered the most at 1.8 front and back?
Old Jan 28, 2002 | 01:43 PM
Matt93SE's Avatar
STFU n00b!
Sprint are a 2" drop, son.
Intrax are 1.75.
Suspension Tech are 1.5.
eibach are 1.2
Old Jan 28, 2002 | 02:12 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
naw, 1.8" all around for the 3rd gens and 2" for the 4ths.
direct from their site-->
"Maxima 89-94 1.80 Front/1.80 Rear 9450"
"Maxima 95-98 2.00 Front/2.00 Rear 9500"
Old Jan 28, 2002 | 03:26 PM
jim90gxe's Avatar
I have sprints and 235/45/17 tires.. no rubbing here. You should be fine.
Oh yeah it's 1.8"
Old Jan 28, 2002 | 09:39 PM
707_Maxima's Avatar
Oh yeah it's 1.8"
what kind of shocks do you have and how much were they?
Old Jan 28, 2002 | 10:07 PM
sxwk12's Avatar
I got the Intrax 1.75 with 215/40/17. No rubbing but the ride is rough.
Old Jan 28, 2002 | 11:39 PM
Ride B Red's Avatar
thats odd, i rub w/ my intrax and 235/45/17's, maybe it just my offset, is 40 the wrong off set for our cars?
Oh yeah it's 1.8"
Old Jan 29, 2002 | 12:10 AM
sxwk12's Avatar
Yes, I think 40 is the wrong offset. Mine is 38.
Old Jan 29, 2002 | 01:52 AM
Bman's Avatar
40mm is a tad high, but to fit 235/45/17s there's a fairly narrow range of offsets we can use. From various sources, an offset of 35-30mm seems like the way to go. sxwk12's wheels and tires fit in part because they're narrower and they're lower offset.
How bad is the rubbing anyway? Big bumps, full-lock turns, etc? Just curious.
Depending how bad it is, you could always install 5-10mm H&R wheelspacers. It also helps a tiny bit if you buy tires without a rim protector bead (a thicker strip/layer of rubber on the sidewall to help prevent "curb rash").
Old Jan 29, 2002 | 11:40 AM
Ride B Red's Avatar
my rubbing
[my tires rub pretty bad when i make full turns and i also noticed a bit of rubbing at he top of the wheel well, but then again my stock tires did that also a tiny bit. where can i get a set of those spacers?, im affraid they will rub on the fender almost, thanx 4 uer help.
Old Jan 30, 2002 | 12:00 AM
Bman's Avatar
Re: my rubbing
Try phoning around some local wheel shops first (what I'd do anyway). Then try searching at google.com and dogpile.com for H&R wheel spacers (or maybe H & R?). I've seen a few places on the internet that sell them, but can't remember which ones. Go to www.hrsprings.com for more info too. When you install the spacers you will have to also install longer wheel studs to replace the ones you have. You can try this yourself if you're mechanically inclined or the wheel shop can probably do this.
EDIT: I just went to their site and apparently H&R doesn't make 10mm spacers... I suppose the 5mm ones will do.
Anyone else?
PS, you get rubbing at the top of the wheel well? Not at on the side of the strut? Maybe get your suspension/strut bumpstops checked because that definitely shouldn't happen with stock wheels.
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
Bucktown
Mar 20, 2001 06:18 PM
