Engine/Trans Mounts
Old Feb 13, 2016 | 04:20 PM
Levsimus's Avatar
Engine/Trans Mounts
Hey there, been a while since I've had the engine and trans out, so I cannot for the life of me remember how many motor/trans mounts there are.
I'm just getting some cheap aftermarket ones from rock auto because money is an issue right now, but I could swear I only removed 3 mounts when I had the engine and trans out way back when, rock auto is listing a front left, front right, rear left, rear right, but not all specify whether they're automatic or manual.
The Nissan parts diagram doesn't help either, since it lists a bunch of extra mounts. Maybe I'm mis-remembering and there really was four mounts?
Its a 1990 and a manual, hopefully one of you old timers has done mounts on a stick and can clarify for me!
Old Feb 13, 2016 | 04:34 PM
akurtzer57's Avatar
Theres two on the motor and two on the trans. I actually have my trans out right now and if needed can snap pics of each one if you need.
Old Feb 14, 2016 | 04:46 AM
Tiniform's Avatar
Yep, 4 mounts. 2 on the engine and the other 2 on the tranny.
Old Feb 15, 2016 | 01:02 PM
Levsimus's Avatar
If it's not too much trouble, I'd actually really appreciate if you could. Would give me a better idea of what I'm looking for/at
Thanks guys for helping clear some of the confusion up! I did check my front mount today, since I can easily see it from above, I see that it's a two piece, that might be what's confusing me on the parts diagrams too, I assumed the engine brackets were all part of the mount assembly, but they look to be a separate part on my phone. I'll need to actually sit down tonight and look back over the diagrams better from my computer.
Old Feb 16, 2016 | 04:18 PM
JoeyChrome's Avatar
Pictures of the Mounts
I have a 1992 SE automatic and a 5 speed, but these should still help you. Even though these are mounts for the VE motor I think at least some of them are the same.
On the automatic, here is the front right engine mount,which is the one near the firewall.
Here is the front left, which is on the engine near the radiator
Now here are the trans mounts for a 5 speed 1992 VE
Both manual trans mounts, left on the left and right on the right
Left side manual trans mount, still installed, this is the one closer to the front of the car
Manual trans mount, still installed, right side, closer to firewall
I hope these help. I'm doing my clutch VTCs and timing chains so I have lots of pictures available.
Old Apr 13, 2016 | 10:25 PM
Levsimus's Avatar
Hey man, I'm super sorry I didn't get back to you to let you know that your pictures helped immensely as well. Thank you so much!
13r1an
62
Jun 13, 2016 10:16 AM
BobMax
19
Feb 29, 2016 07:15 PM
jerrod99_se-l
Jan 13, 2016 05:28 AM
Joseph88
Dec 9, 2015 11:14 AM
