VE30DE supplemental ground wire "fix" at PTU
Old Feb 29, 2016 | 03:06 PM
James92SE's Avatar
2 VE's are better than one!
Doing some extensive searching today, I found mention from old-school Nissan Techs of a "secret" Nissan TSB regarding VE stalling/bucking/hesitating problems.
Apparently, this TSB was a Band-Aid fix of sorts wherein a supplemental ground wire was ran from the power transistor unit straight to the battery negative terminal. I'm amazed that I have never heard of this. Unfortunately, that's all I was able to glean and couldn't find any specifics about it.
Doing some Google searching I can't find this TSB. Has anybody else heard of this "fix" or better yet have any tips on finding the actual TSB?
Old Feb 29, 2016 | 07:09 PM
JoeyChrome's Avatar
I haven't heard of this, but doesn't adding more/better grounds always help? I'm new to the VE however working on the 5.0 Lincolns, whenever we upgraded and added grounds the entire car ran better. I can't technically explain this, it just ran better. Cleaner and more consistent electricity possibly?
On my VE 5 speed I ran all new grounds, sort of mimicking the ground kit that blehmco used to sell. I'm going to get the pinouts for the PTU and simply run a new ground, I don't see how it can hurt.
Old Mar 1, 2016 | 06:30 AM
James92SE's Avatar
Yes more grounds certainly don't hurt, although this is separate from a typical "ground kit" (which I had on my old black VE and didn't help one bit with its stalling issues lol).
I'm just amazed I haven't ever heard of this and that there was some sort of Nissan-sanctioned "secret" Band-Aid fix involving the PTU.
Old Mar 1, 2016 | 07:59 AM
Tiniform's Avatar
If you don't know about it it's probably not true
Old Mar 17, 2016 | 02:41 PM
StevePPD's Avatar
PGMFI
Looking through all of the TSB's I havent seen anything yet on my Nissan system. Any other clues you can give me?
Old Mar 17, 2016 | 04:23 PM
James92SE's Avatar
I think there probably was never an official TSB, perhaps just maybe an inside-knowledge Band-Aid fix amongst Nissan techs years ago.
It looks like the bottom side harness of the PTU, the very center wire is a ground wire. I would GUESS the process is to just tap into that wire and run the other end to the battery negative terminal.
reallywildstuff
Mar 21, 2016 07:51 PM
Ridge43
Mar 4, 2016 02:38 PM
Maxima 97 SE
Feb 29, 2016 09:04 PM
mclasser
Feb 23, 2016 02:07 PM
