Egr block plate
Old May 30, 2018 | 10:00 AM
Vg30ekid's Avatar
Egr block plate
Can anyone post a link or tell me where I can get a egr block plate kit with the bolt that screws into the exhaust manifold? My egr Tube broke and it’s been imposible to find one where I’m at. I have a Ve30de in my car. TIA
Old May 30, 2018 | 11:41 AM
ac max 92's Avatar
I don't think one was ever made for 3rd gens. Though I could be wrong. Could you not fabricate one with some sheet metal and find a bolt to block the other end?
Old May 31, 2018 | 05:17 PM
Vg30ekid's Avatar
This is the block plate on the Ve30de intake manifold idk if someone makes them or made it themselves but it was on the nwp engineering page
Old May 31, 2018 | 11:44 PM
chrome91's Avatar
likely custom made, you can probably just get a small sheet of metal from home depot and use an angle grinder to cut out the shape then drill 2 holes for the bolts
Old Jun 1, 2018 | 12:23 PM
Vg30ekid's Avatar
I used a Coca Cola can but I need something to block the exhaust manifold tube hole
Old Sep 3, 2018 | 05:48 PM
Chris Gregg's Avatar
Get Off My Lawn
I found that the end plate for the cams requires little cutting to fit perfectly. Just use the little egr gasket to mark your lines. Worked perfectly on my turbo. The metal is plenty thick. You should use at least something 3mm thick in aluminum if you have that handy.
Old Sep 3, 2018 | 10:37 PM
CMax03's Avatar
It's not that Complicated,use construction paper or cardboard as a template....if you wanna go with the block off plate...I actually plug my EGR signal line so it never opens, but then I'm not dealing with boost that maybe able to creep the ball off it's seat! When someone inspects under my hood during emission testing it virtually looks OEM!
Old Sep 15, 2018 | 02:29 PM
juggalo_g's Avatar
So nobody knows what the bolt plug size is for the exhaust manifold
Old Sep 17, 2018 | 05:14 AM
CMax03's Avatar
The EGR tube fitting size on the manifold?
Old Sep 17, 2018 | 08:52 AM
juggalo_g's Avatar
Yes the tube that runs to the exhaust manifold what size bolt or plug was used
Old Oct 11, 2018 | 07:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
it's a weird metric pipe thread. what you can do is cut the tube. take that "bolt" the tube ran into and have someone weld a blank plate over the top of it and then screw it back in and you should be ok.
Old Oct 12, 2018 | 06:57 AM
RA030726's Avatar
I'm nutty for Nissans
Unscrew the tube, insert a coin (nickel), reattach tube or at least the threaded part.
Or if you have a Nissan exhaust manifold laying around, check to see if it has a reducing bushing for an O2 sensor. They used the bushing on many different cars and it's the same size as the EGR bung. Unscrew it and plug it with a nickel, old O2 sensor or an easier to find bolt.
Old Oct 12, 2018 | 07:05 AM
RA030726's Avatar
Or buy the plug, part number 14052-21R00.
max ride 41
Mar 2, 2017 02:02 PM
Hoffm2ma
Jan 13, 2012 09:19 AM
maxspeed96CT
Aug 14, 2011 11:40 AM
