New muffler
Old May 2, 2019 | 04:17 PM
GregL65's Avatar
New muffler
I need a muffler for my '90 SE. The old type with two 1.5" diameter outlets is no longer available. Instead Autozone suggests one that fits but has only a single, 2" outlet.
Two 1.5" outlets have a total area of 3.5 sq in. A single 2" outlet has an area of 3.14 sq in.
Should I be concerned about that difference? Is a single 2" outlet enough for a '90 Maxima?
Here's the part no longer available, with the two 1.5" outlets:
https://www.autozone.com/emission-co...50_416176_1995
Here's the available part they suggest, with the single 2" outlet:
https://www.autozone.com/emission-co...53_332769_1995
Old May 2, 2019 | 10:57 PM
jordez1's Avatar
1990 SE new muffler
1993 Maxima OEM muffler OEM Duel tips
Old May 2, 2019 | 11:05 PM
jordez1's Avatar
2004 Maxima SE OEM Calsonic duel tip
2004 Maxima SE exhaust on a 1990 Maxima SE
1990 SE with newer Maxima exhaust
1990 SE with cheap exhaust from Autozone
1990 SE with low quality exhaust
Old May 2, 2019 | 11:15 PM
GregL65's Avatar
Thanks for the pictures, but I'm not asking what they look like. The muffler it had for the last 10 years until it rusted out and fell off was from Midas and looks similar the Autozone one.
What I'm asking is whether the 10% reduction in outlet area would significantly affect performance. If so, I'll need to go to a muffler shop and have a generic one welded on.
Old May 3, 2019 | 05:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
nope, you should be perfectly fine.
Old May 26, 2019 | 09:08 PM
CMax03's Avatar
You can find one of the many 5.5th Gen Maxima(s) and graft their muffler to fit your exhaust. The hangars are all in the same location....
Old May 26, 2019 | 09:15 PM
GregL65's Avatar
I was able to discuss it with the mechanic and he said it should be fine. But when I tried to order the one with the single 2" outlet, it turned out to be not available even though the website said it was.
So I took it to a highly regarded local muffler shop, and they welded on what I suppose is a generic one. It has a single 2" outlet. Works fine.
Chiselchin
Sep 19, 2017 05:43 PM
boondoxmax
70
Apr 24, 2017 05:22 PM
KiNgJaMEs
Nov 29, 2008 06:34 PM
devilz05
Feb 26, 2006 11:05 AM
BigDogJonx
32
Jan 5, 2002 10:00 PM
