Battery drains even without key in ignition
Old Dec 2, 2020 | 11:28 AM
GregL65's Avatar
Our '90 SE seems to be draining the battery even when off without the key in the ignition.
At first I assumed the problem was the somewhat old battery, so I replaced it, but I'm getting the same problem with the new battery.
Any suggestions?
Old Dec 2, 2020 | 05:34 PM
Darkwing48's Avatar
Radio?
Headlight Switch? Does your high beam light come on even when your lights are at low beams?
Old Dec 2, 2020 | 07:03 PM
crazy4maxima's Avatar
Sounds like an electrical drain somewhere. Obviously did you check and make sure the dome switch and all interior lights are off when you leave? All doors closed and the trunk?
Old Dec 3, 2020 | 12:20 AM
GregL65's Avatar
Hi all,
Yes, I've checked for lights, radio, etc.
With the key NOT in the ignition, the door chimes when I open the door. Should the door chime when the key is not in the ignition? To my recollection that normally only happens if the key is in the ignition.
Old Dec 3, 2020 | 02:22 AM
Originally Posted by GregL65
Hi all,
If you've removed the key from the cylinder the only warning chime you should get is when the light parking/headlight switch is left on. Also when closing the door and locking it does the security light come on and go off after a few seconds or does it stay off? Maybe its a bad relay in the drivers fuse area. Swap the blue accessory relay and see if that changes anything. All the switches on the master panel door work?
Old Dec 7, 2020 | 08:37 AM
CMax03's Avatar
Any suggestions?
I'm fighting a problem like that on a local Maxima of a private owner and what I've found so far point is the positive battery terminal fusible links/ bus connectors have a 12 volt pull that are directly attached to the starter, alternator, and Ignition switch!
Old Dec 7, 2020 | 08:40 AM
CMax03's Avatar
Hi all,
I also checking all the fuses, pulled all the fuses and that lead me to the positive terminal with those two or three wires tied to it!
Old Feb 16, 2021 | 05:08 PM
GRNMAXDMON's Avatar
CMax03, so it seems i too have been having the same issue for some time now. My car would start fine one day if not for a whole week with no issues but if i let sit for more than 2 days, it will not start and give symptoms as if the starter was bad. I replaced all 3 critical components, battery, starter and alternator. Once all 3 have been replaced it still gives the same issue where it will not start but just exhibit clicking noise once i turn the key as if again the starter is bad. Then i leave it alone for nearly 4 days and then my battery is completely dead. Now i went ahead and replaced main positive battery cable from battery to starter but not sure if the fusible link is possibly bad? or both links are bad? I went ahead and swapped starter relay but again not sure if that is also good as i got it from the junkyard. So, i basically unplugged the connector that goes straight down to starter and just installed a wire directly from the positive battery terminal to the female end of the connector and the car starts? Any suggestions as to what else i can do?
Old Feb 16, 2021 | 06:17 PM
GregL65's Avatar
I had a mechanic look at it and I think our battery drainage problem is solved.
He found that the hood sensor -- the one that senses whether the hood is open -- was not functioning correctly, and, if I understood him correctly, it was sending frequent signals that the hood was open. He disabled the sensor. He tested the battery for a draw after that and found that there was no draw on it.
I bought a new battery -- by then the battery, though only about 6 months old, had been drained so many times that it still would not hold a charge for more than a couple of days even after disabling the hood sensor. It's been a few weeks and we've had no problem. I suppose it's possible we're still in the process of draining the new battery and will soon have the same problem again, but I'm hopeful that disabling the hood sensor did the trick.
Old Feb 16, 2021 | 07:40 PM
GRNMAXDMON's Avatar
Interesting how that would do cause your problem. Not sure if im having the same issue? Hopefully someone on here can shed more on this. Another thing I meant to ask is how the 2 wires coming out of the small red box on the positive battery terminal work? What controls it and what its function is?
Old Feb 16, 2021 | 08:57 PM
CMax03's Avatar
I don't trust those 2 connectors on the positive battery terminal....I had problems with mine on my 1990 and I removed all that and placed the battery in a remote battery box (Vented) eliminating all that crap!
Old Feb 17, 2021 | 03:06 AM
GRNMAXDMON's Avatar
So what exactly did you do to eliminate it and how did you make it work?
Old Feb 17, 2021 | 11:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
when everything worked....
if the hood was opened while the car is locked. it would honk the horns and flash the headlights. who knows what the previous owner did...but you probably hear the relay clicking when the hood switch goes haywire but not actually sound the horn the flash the lights.
DC_Dude
Mar 30, 2018 07:25 AM
J-LO41
Jan 8, 2015 06:58 PM
rh0214
Oct 12, 2011 09:34 AM
Olezhka
Dec 4, 2007 05:14 AM
