89 Max Transmission Strangeness
Old Nov 4, 2021 | 02:50 PM
TX89Max's Avatar
So I have an 89 Maxima, I drive it almost daily but the transmission does not always like to shift into drive. I am unsure what the issue would be. There's no rough shifting or trouble shifting after the first time it actually shifts. It simply doesn't always shift when the lever is pulled to drive. Any clues what the issue might be? I'm assuming it's most likely electrical because of the intermittent trouble it causes.
Old Nov 4, 2021 | 04:06 PM
DanNY's Avatar
Ad·min·is·tra·tor
is the shifter sloppy? like loose? there's a shifter cable bushing that goes on both ends of the shift cable. if that's worn that will give you issues with getting to D (it thinks it's in N).
next time shift it to 2 and see...if it's good then it's most likely the bushing. does the key also not come out when you put the car in park?
if none of these then you might actually have transmission issues...check fluid and top off if needed and change if it's in bad shape.
Old Nov 4, 2021 | 04:38 PM
TX89Max's Avatar
It doesn't shift into 2nd, 1st, or D, at least sporadically it wont. It shifts quite smoothly when it finally does shift. The key comes out no matter what, never had issues with that.
Old Nov 7, 2021 | 11:43 AM
mcx's Avatar
mcx
...run the trans troubleshoot code check sequence..see if any codes are stored.
Old Nov 11, 2021 | 06:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
how's the fluid level?
Memitoad
Dec 20, 2019 11:45 AM
Jacken
Sep 16, 2019 05:24 AM
itsTrueMental
Nov 17, 2013 07:36 AM
getflushed
Jul 30, 2011 03:29 PM
wutsup
32
Feb 24, 2006 04:57 PM
