Maxima 1989 - Failure to accelerate
Old Dec 18, 2024 | 04:32 PM
Joshua0907's Avatar
I have a 1989 Nissan Maxima that is giving me many problems when I accelerate, as once it exceeds 3,000 RPMs, it starts to cut out intermittently and I don't know what it is.
This issue starts after revving the engine above 4,000 RPMs. It doesn't happen immediately, but after two or three days, it starts to show this problem.
The issue stops happening after using it for several weeks, but I am limited to not exceeding 4,000 RPMs, which is very difficult because I live in an area with many steep slopes and it is quite likely that one day I will exceed 4,000 RPMs, causing the problem to recur.
This is the fourth time this has happened to me.
Another detail is that, as days go by using it, the issue occurs at lower and lower RPMs.
I would appreciate your help
Old Dec 19, 2024 | 01:44 AM
chrome91's Avatar
When is the last time the distributor cap and rotor were checked/changed out?
Old Dec 19, 2024 | 06:55 AM
Joshua0907's Avatar
It was replaced a month ago, thinking that was the problem, but it continued having the same issue
Old Dec 19, 2024 | 01:38 PM
chrome91's Avatar
Hmmm have you tried testing the mass air flow and checked how good the spark is?
Old Jan 1, 2025 | 10:14 PM
vonkas's Avatar
Had identical issue! Found cold solder joints in the MAF sensor. Cut the cover open and find the wires from the connector going into the circuit board. Just resolder these. I sealed the sensor with duct tape and it's been working for years like that.
angelsdv
27
Oct 1, 2022 10:01 AM
Abood
Oct 4, 2020 05:18 AM
BlackNYMax
Oct 1, 2019 10:17 AM
crashmanmike
May 17, 2003 07:01 AM
