No start
Old Aug 23, 2025 | 11:32 AM
abunai's Avatar
No start
1990 GXE auto
Funny thing happened yesterday.
Went to the mall, about an hour later it wouldn't start.
Started good, sounds good, just not catching.
Tried it 3 times.
Waited for about 10 minutes, tried again, and it started.
Ran fine like normal.
Drove it home without any problem.
Only thing I noticed is the speedo needle, when driving, won't go back to idle.
Let it sit for an hour, and it started right up.
I'm thinking a dying fuel pump relay.
The printing on the relay box cover is all worn away.
Where can I find a picture of it, so I can see which relay is what???
Any other suggestions????
Old Aug 23, 2025 | 07:56 PM
chrome91's Avatar
I've seen failing distributors cause those symptoms as well, when the engines warm the contacts in the distributor heat up and break connection causing a crank no-start when heatsoaked, when the engine cools a bit the connections join back together and let the car start
but it can be many things that cause this, when driving what does the speedo needle do? just sit dead?
Old Aug 23, 2025 | 08:12 PM
abunai's Avatar
I did change the distributor about 3 years ago.
It was a rebuilt and was so cheap.
It did have the original one in it.
It starts a "0"then it goes up like normal, but doesn't come back down to "0".
When I turn off the engine, it goes back to "0".
It drives fine.
Old Aug 24, 2025 | 02:12 PM
FanaticMadMax's Avatar
it can be a number of things, first have you have your battery and starter tested, take it to your local parts store like autozone or O'Reilly's see if they can test it, they are free services. Before you start chasing down issue with distributor and other parts .
Old Aug 24, 2025 | 11:39 PM
abunai's Avatar
I did test the battery, and it's strong.
Everything is working fine now.
Just started it and didn't drive it.
Have some spare relays, so I'll put them in the car.
Old girl is just showing her age.
Old Aug 25, 2025 | 04:04 PM
abunai's Avatar
Checked it and I think the fuel pump is just getting old.
We have that useless ethanol in the gas here, and it caused all kinds of problems.
I'll just change the pump and strainer.
Old Sep 2, 2025 | 11:09 AM
abunai's Avatar
Changed the fuel pump.
Seems to run much better.
Filter was not clogged or dirty.
Had to lower the idle speed a tiny bit.
Ray229Harris
May 24, 2017 01:53 PM
abbey
Nov 28, 2001 10:15 PM
weim
Aug 4, 2001 01:04 AM
Dan E
Jun 1, 2001 05:56 PM
