Speedo problem
Old Dec 28, 2025 | 10:14 AM
abunai's Avatar
Speedo problem
1990 GXE auto
Kind of strange thing happening.
The speedo, when driving, goes up to 35mph and just stays there.
When I stop, it will go down to 5mph.
It runs and shifts fine.
I'm thinking a bad ground wire to the dash.
Everything else is working fine.
Anyone else had this problem???
Suggestions???
Old Jan 18, 2026 | 05:21 PM
abunai's Avatar
Since no replies, I'm guessing not a common problem.
I checked the sensor.
It puts out voltage when I can spin it fast enough.
So it looks like it's working.
I left it disconnected, and the speedo didn't work at all.
Plugged it back in, and same problem.
Going to have to pull the panel out next.
Old Jan 22, 2026 | 10:52 AM
Hectic's Avatar
Unless the voltage plateaus when rotating the sensor, it's likely going to be the speedometer itself.
Old Jan 22, 2026 | 11:14 AM
abunai's Avatar
It has to be spun fast to get anything out of the sensor.
Can't keep it spinning at a constant speed for long.
I wound a string around the gear, and pulled, that spun it fast enough to get a reading.
I'll just have to pull the panel out and look if I can see anything.
Do some testing of the circuit.
Old Jan 24, 2026 | 08:47 AM
Hectic's Avatar
You can remove the pinion temporarily and run it with a drill for testing.
abunai
Feb 23, 2023 03:50 AM
slowalty
25
Nov 5, 2005 04:33 PM
Wiking
Feb 1, 2005 12:18 PM
03G35
Mar 9, 2004 10:36 AM
