high/low beam on at the same time
Old Feb 28, 2002 | 11:04 PM
ngthing's Avatar
i read some older posts and it was said that if i remove my light rod, there is something mechanical in the actual rod i can modify so my high beam and low beams can be on at the same time.
can somebody give me some direction on this? i'd rather not use a bunch of relays.
Old Feb 28, 2002 | 11:09 PM
Evil Yak's Avatar
that was me
gave one of them to brandon90GXE
both of us have real high/lowbeam capability
none of that oh so reliable relay BS
wow im feeling weird tonite
im going to bed
Old Feb 28, 2002 | 11:19 PM
mykizism's Avatar
Originally posted by Evil Yak
that was me
im going to bed
hey whats wrong with relays.. thats what im using
if there is a better way, some one shoot me a email or message
Mykizism@hotmail.com
Mykizism = AIM
Old Feb 28, 2002 | 11:23 PM
Matt93SE's Avatar
STFU n00b!
transistors are the only thing more reliable than the relays..
but in order to do the relays, all you really need are a coupld diodes. install them between the high beam and low beam signal lines before the relays, with the striped end pointing toward the low beam one... that way when you activate the high beam, it'll also activate the low beam...
Old Feb 28, 2002 | 11:42 PM
mykizism's Avatar
hmm i didnt use any diodes on my setup,
what i did, was use 3 relays
two of the relays are from the stock "upgraded harness", and i cut off the old 9004 sockets, and replaced them with the autozone brand 9006/9005 sockets.
lets state this
low beam relay = A
high beam relay = B
3rd relay = C
note* they all share a ground wire
with those two relays i added a third one, with power coming from the A relay to power the C relay to power it. and the signal switch from B relay to the C relay
so when i activate my high beams with out my low beams ON, only the HIgh beams light up, rather than all 4 lights lighting up
and when i have my low beams on and switch my high beams, the low beams stays on, and my high beams light up too.
Old Mar 1, 2002 | 01:21 AM
Bman's Avatar
lets state this
low beam relay = A
high beam relay = B
3rd relay = C
Clever. The "juggling relays dance" always gives me a headache I'll have to remember this little setup!
What's this rod/bar thingy though?
Old Mar 1, 2002 | 01:25 AM
mykizism's Avatar
i think what ngthing is refering to is.. modifying the actual head lamp switch next to the steering wheel..
though i never actually took it apart yet.. i dont think i want to either, relays seems simpler since, if i ever should decide to take out the hid and bmw lamps i can just take out the relays too
Old Mar 1, 2002 | 01:39 AM
ngthing's Avatar
i've been yaked.
the yak way was VERY simple, all i had to do was remove the switch, remove some screws, and pry open this one part (which took the longest), then grind down a piece of plastic.
i'm very happy, it won't fail, and well, it's really cool
Old Mar 1, 2002 | 01:46 AM
mykizism's Avatar
Originally posted by ngthing
i've been yaked.
so ngthing, when you have your low beams off.. you can switch on your high beams on , with out having your low beams turn on too right?
and when you have your low beams on.. and you switch on your high beams.. both stay on?
Old Mar 1, 2002 | 01:55 AM
ngthing's Avatar
when i have my lights off, i can turn the high beams on, and ONLY the high beams will go on. when i have my low beams on, and turn my high beams on, or i "flash them" with the stick, the low beam stays on.
i was taking pictures of the install process, but the camera crapped out on me.
Old Mar 1, 2002 | 01:59 AM
mykizism's Avatar
awesome.. thats exactly what my relays do. instead of the stupid relays.. id rather just modify the stick.
i guess i`ll take it apart this weekend and take a look-see
or if not, my relays do what i wanted them to do.. haha pretty fun
Old Mar 1, 2002 | 02:19 AM
ngthing's Avatar
yup, modify teh stick. most of the time yu sped on this projdct will be taking apart the steering column and getting to the stick.
(it took me 15 mins overall at most)
quite simple.
Old Mar 1, 2002 | 07:07 AM
Evil Yak's Avatar
i like this mod cuz it seems more reliable than relays
relays are reliable and all, but with the heat and moisture
getting all over into the engine bay, how reliable can they
be? besides, relays look sloppy in the engine bay and it's pretty
hard to mount them so they look nice.
if you guys want, i have a tiny writeup and some pix to go along
with the writeup
Old Mar 1, 2002 | 04:46 PM
Brandon90gxe's Avatar
that was me
im going to bed
works awesome dude!
i first had the setup with relays and it wasnt all that great. If you flashed the highbeams with the low off, it turned on both sets of lights. so if my alarm when off it flashed the HID and the highs, which isnt good for the HID.
The Yak way, the high beams are seperate, which is much much better. so if im crusion on the high way too fast and a cop spolts my lights, ill just turn off the HID and hold on the high beams and hopefully he wont recognize me
Old Mar 1, 2002 | 05:59 PM
ngthing's Avatar
you've got a automatic GXE, probably won't have to worry about going to fast
mvm062
Nov 30, 2020 09:00 AM
Maxima.KsA
May 15, 2020 04:14 PM
intimidator
Sep 5, 2015 07:23 PM
delerium75
Aug 19, 2015 11:08 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
