What chemical to remove tint?
Old Mar 12, 2002 | 12:33 PM
edpaek's Avatar
Just got a beat up 89', but has some sick dark tint that is old and failing.... what do i use to soak the tint in? Do i have to remove the rear windshield to soak?
Old Mar 12, 2002 | 01:08 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: What chemical to remove tint?
ammonia or tint-off.
no u don't have to remove rear glass.
Old Mar 12, 2002 | 02:22 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: What chemical to remove tint?
after you get it off use goo gone (can get it from walmart) and a razor blade to get the left over sticky off.
I used it and it worked great.
Old Mar 13, 2002 | 04:08 AM
Dave S's Avatar
About how long does the ammonia or "Tint-Off" have to sit on the window before the tint will come off? Does it peel off, or kinda come off in clumps? I have some nasty brown tint I'd love to get rid of.
Old Mar 13, 2002 | 05:37 AM
nupe500's Avatar
Jedi Knight
Re: Re: Re: What chemical to remove tint?
DO NOT USE A RAZOR on your rear windshield...because you will damage your defroster lines...would not be good....but it will take some elbow grease with that goo gone...and that will work...
Old Mar 13, 2002 | 06:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
well for the back window you should let it sit under a hot sun baking for a few hours. after u spray the glass get a black plastic bag and cover it to retain the moisture and the heat. make sure the ammonia doesn't dry. the tint will get soft and it will prob pull off w/o much effort. the glue will be also soft..so get a **PLASTIC** razor blade and carefully scrape the glue off w/o too much damage to the defrostor lines.
for all the others windows spray some ammonia/tintoff on and use a stainless steel razor blade and scrape off the tint/glue...not carbon steel. use a **WHITE** scouring pad and scrub the window to get rid of last bit of glue...(do not use the green ones..it'll scratch the glass).
ok this has been typed out once too many by me....so in the future people can do a search and find this information again.
Old Mar 13, 2002 | 07:54 AM
Michael's Avatar
Back in a 3rd Gen.
Oops...Thanks for correcting that I wasn't even thinking about the rear defroster lines and your definetly right don't use razors on the glass with the defroster on it.
Old Mar 13, 2002 | 08:37 AM
edpaek's Avatar
Listen everyone... Thanks for all the help... the tint is so bad in my rear i cant see thru it! But agian thanks for all the info all!
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
