Fuel Injectors
Old Mar 19, 2002 | 08:45 AM
pimpofbrooklyn's Avatar
Fuel Injectors
Hiya Guys,
just a quick question. I am going to order new injectors for my 1989 Nissan Maxima SE, and just need to know how many i have to order & they are asking me for this: blue or black? Which one should I have to get? It's an automatic. Any good websites I should check out to get nissan parts?
Old Mar 19, 2002 | 09:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Fuel Injectors
Originally posted by pimpofbrooklyn
Hiya Guys,
they say there is dot (blue/black) is on the actual injector...i never seen them.
it's a good idea to do all 6.
check out prices on parts here http://www.courtesynissan.com/
Old Mar 19, 2002 | 10:56 AM
Bill Doran's Avatar
Injectors
There is a painted dot on the injector under the electrical connector. I believe if you are changing all 6 the color doesn't matter, as long as they are a matched set. I buy mine at:
http://thepartsbin.com. They are in NJ and ship free if order is over $50. Be sure to replace O-rings. The parts bin does not stock the small ring, only the large
Old Mar 19, 2002 | 03:37 PM
ChrisCheezer's Avatar
how do you know when to replace them
ok my car has a odd idel.. sometimes good some times almost stalling, When this happends my Rpms DRop very very low and the shakes.. the car has never had any work, every thing in the car now is right from the dealer, spark plugs, ingectors.....on on on i have a 90Se w/82k miles. shes starting to run a weak .. what should i do?
Old Mar 19, 2002 | 05:20 PM
MaxinG
Re: how do you know when to replace them
I had a similar problem solved today. It idled ruff in park and even worse in drive. I first identified it was the injector by pulling the wire and checking for spark on each plug. Also making sure the idle changed when I removed each wire. When I identified which wire when removed didn't change the idle, then I knew which cylinder is not firing. Then when I had a spark at the same wire I knew it wasn't the wire. Ithen swopped plugs and the condition was the same. So only thing left was a bad injector. The color can only be seen when you take the top manifold unit off. I changed one injector at a cost of 57 dollars for the injector and the car workedfine. The hoses and other parts require patience and it took me about 4 hours of step by step patience. I hope I helped clear things up for you.
Old Mar 20, 2002 | 10:25 AM
nismo1989's Avatar
Re: Re: how do you know when to replace them
Next time do a voltage test to check the wires. You can check the injectors by listening to them.
Old Mar 20, 2002 | 10:30 AM
bucketheadd's Avatar
Re: Re: Re: how do you know when to replace them
I believe you can see the dots on the front rail but not the back
Old Mar 20, 2002 | 01:02 PM
CoolMax's Avatar
is invisible
Duh...what makes fuel injectors go bad?
Old Mar 20, 2002 | 02:15 PM
eric93SE's Avatar
When particles get past the fuel filter, then get stuck at the filter screen on the injector itself. Gas acts as coolant for the injector, the coil inside the injector can run very hot, and the gas cool it. The more clogged the injector, the hotter it runs and eventually it overheats and the coil fails (dead short). Sometimes its just the connector itself which has a layer of oxidation that needs to be cleaned. Or the injector can be leaking (which is the problem I'm having, engine is missing) and I'm hoping it is simply the o-ring's which need to be replaced. I'm getting kinda crappy fuel economy 20-21(under controlled conditions), for a ve that sucks. This comming week I've got spring break so I might go ahead and do the job, wish me luck .
Old Mar 20, 2002 | 03:07 PM
MaxinG
Eric, good luck with the work. 90% of it is removing and replacing those hoses.
Old Mar 21, 2002 | 11:24 AM
eric93SE's Avatar
Yeah I realized that, and so I decided to simply cut them since they will be replaced anyway.
I'm also glad I'll be able to get at the knock sensor. Mine is reading a resistance, I forget now how high it was but in the meg-ohm region. So I wanna clean all the contact for the knock sensor.
Old Mar 21, 2002 | 11:52 AM
Taegost's Avatar
At the voltage running thru the engine, if it's in the M-Ohm, then it's prolly either really dirty like you said, or open... As in burned up.
Old Mar 22, 2002 | 09:00 AM
CoolMax's Avatar
is invisible
Thanks eric.
I suppose filling up the gas tank before it hits empty doesn't help any.
Old Mar 22, 2002 | 10:54 PM
blackandwhite's Avatar
To them I'm like an idol
Is Bigger better
I've seen some aftermarket "Super-flow" injectors for our cars (the VG at least). Do these real help any, I got a CAI so I got higher air flow. Will higher fuel flow add performance, or will they even flow more fuel with an ECU upgrade.
Old Mar 23, 2002 | 09:35 PM
eric93SE's Avatar
Na man... you dont need higher flowing injectors. If aftermarket injectors were too far from factor spec. then the computer could not properly control their pulse width to give the proper mixture.
I found that Beck-Arnley makes a tune-up kit for our injectors (153-0155 for the ve, and 153-0148 for the vg) oddly enough the kit for the vg is more expensive than the ve. But I do not know exactly what they come with. I'm assuming it's the upper and lower o-rings with the spacer ring, but then what else, does it come with new filter screen and pintles . Anyway I'll be ordering the kit for the ve monday through a local import dealer, and if he cant get it, then I'll pick it up through the internet.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
