interior paint?
Old Mar 19, 2002 | 01:32 PM
maxman16's Avatar
interior paint?
you guys seem to know what your takin about so here it goes.
How many cans of primer, paint and sealer do i need to paint the interior of my 91se? I want to do most of the front dash. everything that is hard anyway. i dont want to run out of paint because i am probably going to buy it online from jcw.com
Old Mar 19, 2002 | 02:35 PM
noleafclover's Avatar
Re: interior paint?
i did this recently (am in the process of actually) can't really help you out on your ?, but i used regular old paint, that was like a dollar at the hardware store, looks great. i don't see the point in spending more on "interior paint" or whatever.
Old Mar 20, 2002 | 08:34 AM
bjyang
regular paint will chip off. the cheapest would be to get paint for vinyl. the first time i painted the interior...in about a month it started chipping off. then i got paint used for vinyl.. works great!!
Old Mar 20, 2002 | 09:10 AM
nismo1989's Avatar
It's hard to remember for sure but it seems like I got 6 cans of primer, 8 cans of paint and 4 cans of clear sealant...
Old Mar 20, 2002 | 09:21 AM
N34JZ's Avatar
Needs non-Maxima Friends
ummm Im the expert here lol
my interiors
use krylon, but vinyl paint isnt for plastic, unless your talking about the actuall dash not the console.
here are some directions
After you take the peices out wipe and clean them with paint thinner, once they are dry(must be absolutly dry)
put on a light coat of primer(must be same brand as paint)
you dont even have to cover all the area, just dust it. now use a heat gun (blowdryer will work too) and dry it, about 60-90 seconds later, dust it again, and repeat it till you have an even cover of primer, let it dry for a few hours heating every so often.
then follow the same steps with the paint(except cleaning it with paint thinner lol)
but put about 30-50 thin coats, 60 second between (make sure they are thin coats)
then let it dry for a few hours (heat speeds it up)
then use clear coat,(smae brand as paint and primer) and do the same thing untill the can is finished.
you can use any brand of paiint most of the time is use two colors with one matching body color so I use automotive paint which works fine.
If your paint started to chip its cause you didnt prep it right and the paint job was sh!tty.
Old Mar 20, 2002 | 09:45 AM
bjyang
my fault....i thought this thread was about the dashboards..etc..
Old Mar 20, 2002 | 04:22 PM
ChrisCheezer's Avatar
my paint is holding up
ok i painted alot on my dash . ... i used a blow dryer and just reg. spray paint.. a few very small chips but nothing the untrained eye would see. Im going to paint every think again.. ill have my camra
Old Mar 20, 2002 | 04:27 PM
Dummy's Avatar
when i painted mine, i just used regular model paint, that "testors" stuff, and i used clear coat over it and it isnt chipping.
Old Mar 20, 2002 | 04:30 PM
N34JZ's Avatar
Re: my paint is holding up
you should let me Ill hook it up, just drop off your dash one day and pick it up in a few days and walla
Old Mar 20, 2002 | 05:49 PM
sxwk12's Avatar
I started painting the black interior pieces that were not touched when I had it done in green and white.I think I asked James for the advice and the advice he gave worked pretty good (sand it down, couple coats of prime, couple coats of color, wet sand, couple coats of clear). One thing I like about the clear is that it makes it so GLOSSY (the more coats of clear = the more glossy). So far I have only done my driver side rear door and the piece that goes around the radio. But one thing I do not like about it, is that the buttons (windows, door locks, defrost, fogs, etc) are still black, the AC/Heat and radio are still black and it looks kinda tacky. I was thinking about painting the buttons since I know what each one of them go to. But I was also wondering if the little drawings on the buttons could be made by someone in here or by someone at all. Anyway, if it ever warms up and stops raining, I will finish the job and take some pics.
Old Mar 20, 2002 | 07:24 PM
MaxManMo420's Avatar
I have interior primer and paint do i really need clear coat or is that just to make it glossy?
Old Mar 20, 2002 | 08:32 PM
nismo1989's Avatar
That makes it glossy, but more importantly it protects the paint from chips and dirt. Highly recommended. Otherwise, you're gonna have to take it all apart and redo it. Trust me, I'm goin on my third redo because of color change and not taking my time...
Old Mar 20, 2002 | 08:53 PM
sxwk12's Avatar
Could I paint my front lip with this same process? Or does it HAVE to have the oven like garage? You know sand it down, prime it, paint it and hope the wind doesn't blow anything on to it while it's wet. Can this be done? I think I might try it. Opinions, anyone?
Old Mar 20, 2002 | 09:08 PM
nismo1989's Avatar
It not only makes it glossy but more importantly it protects it from dirt and chipping. You should clear coat it. Clear coat at Pep Boys is $5 for 2 cans, more than enough...
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
