temperature meter
Old Mar 20, 2002 | 08:13 AM
Giovanni's Avatar
temperature meter
When my car is stuck in traffic the needles goes close to RED, then the fan goes on. Its not suppose to go on way before this?
Fan relays seems to be good. One other thing I noticed, the fan doesn't go on when the A/C is switched on.
I changed the thermostat with an aftermarket one like 2 years ago.
Any ideas?
Thanks...
Old Mar 20, 2002 | 09:34 AM
phat's Avatar
How old is your coolant? Check your temp. sensor. It's probably too old.
Old Apr 3, 2002 | 06:10 AM
time2reup's Avatar
Whatever you need to fix you better do it quick, letting your max overheat like that is asking for head gasket...and that's not something you want to deal with...
Old Apr 4, 2002 | 05:22 AM
phat's Avatar
Originally posted by 1989 4DSC
It never overheated. I turned the heat on when the needel started to climb.
What is the temperature of the thermostat? Did this happen before u replace the thermostat? U might want to install a lower temperature thermostat so that it will open at a lower temp.
doctorpullit
Oct 28, 2019 10:58 PM
Smackasmith
Feb 1, 2016 12:40 AM
bryants95max
Oct 2, 2015 12:52 PM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
