My Antenna
Re: My Antenna
Be more specific. The antenna mast or motor broke? you can get oem mast for ~50$ and use the old motor. If you need the whole thing, cheapest is probably someone parting out a max or a junk yard.
Originally posted by pest2001
My Antenna broke on saturday is there a ways to fix it or do i have to get a ne one and if i have to get a new one where can i get it cheap
thanx
william
thanx
william
Re: My Antenna
thanx
william
thanx
william
Originally posted by CometMAX
My antenna used to grind when it gets 1/3 of the way up. Now it doesnt grind anymore and its stuck the the down postion. I'm so ****ed. Is there a way to get that thing out? Or am I screwed?
into the motor gear. If the inside is dirty, just clean it and put new grease in and it should work fine. If the mast is broken, replace it. I asked the dealer and they want $35
If anyone can find it cheaper let me know.
GO TO E_BAY NOW
Originally posted by phat
If your antenna motor still work but the mast doesn't go up/down all the way, remove the antenna. The two common problems with antenna is after a while, the grease inside collects dirt which cause the mast on the antenna to jam up. The other problem is the plastic white rope-like part that push or pull the antenna is either bent, broken, or worn out. For maxima, the rope-like part have grooves on them that sblime:rolleye s: into the motor gear.
If the inside is dirty, just clean it and put new grease in and it should work fine. If the mast is broken, replace it. I asked the dealer and they want $35 :laug h: If anyone can find it cheaper let me know.:kiss :
Antenna repair info on repair...
Phat- 35 bucks is a good price.. especailly on oem... look on e-bay look at the low prices on e-bay
hey get it..:P. its oem... I have aftermarket antenna.. big mistake.
. b/c i no longer use the stock harness,.. so do it... and have fun.. make certain that you put back your seat belt backet back on
Re: GO TO E_BAY NOW
Originally posted by crazy4maxima
your right.... so do it..
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
well this info was really for comet
