Front end shaking @ 70mph, wheel balancing?
Old Apr 11, 2002 | 02:34 PM
AC439's Avatar
Hi...Haven't post for a while. Just went thro' a job lost and am in a new job, anyway.....
My 92 SE starts to shakes when I approach 70mph. I can't determine if I need wheel balancing or not. The reason I said that is there is a part of the freeway (the part that looks a little darker in color) is shaking. But when I go over the overpass where the concrete is lighter in color, the shaking is lesser.
I had my left outer CV boot replaced a few months ago. I wonder if this would be the cause of the problem (assume the mechanic didn't do a good job). I talked to a co-worker today and he mentioned if the shake comes at 70mph, could be the drive-axle.
Anyone has an insight for me?
Thanks.
-AC
Old Apr 11, 2002 | 02:44 PM
Matt93SE's Avatar
STFU n00b!
could be a bad tire, bad balance, or a funky CV joint install.
When I replaced one of my CVs a while back, I had the same deal.. after spending $2000 on new wheels, tires, complete suspension, brakes, the vibes were still there.
Finally I had another CV boot blow out on me, so I had to pull the joint out.. when I put it back in the vibes were gone.
Soooo, your co-worker might be right in your case. pull the joint out, give it a 1/2 turn, and shove it back in. it certainly can't hurt to try!
Old Apr 11, 2002 | 02:52 PM
AC439's Avatar
I'd certainly like to try rotate 1/2 turn. How hard it is to get the drive-axle out? I can only work on my driveway so I'm not sure if this is an easy job or not. One time, I watched a mechanic work on my Honda's CV and he was hitting and banging hard to get the drive-axle out. Do I need special piling tools? Thanks.
-AC
Old Apr 11, 2002 | 05:10 PM
ChrisCheezer's Avatar
yea...i had that too
if yo got your tires at pep-boys they will do a full balance for free
if you go to get them looke dto them tell them that it starts shaking at 75 mph
Old Apr 12, 2002 | 12:52 AM
tilt's Avatar
Re: Front end shaking @ 70mph, wheel balancing?
I had the same symptom as you. Whenever I hit around 70 or above the steering would shake like crazy. I replaced my tires and the problem was gone. I'm gonna guess either my tread was too low or they just needed balancing.
Thanks.
-AC
Old Apr 12, 2002 | 07:41 AM
AC439's Avatar
Thanks guys ! I think I'll do a 4 wheels balancing first since it's due for that anyway. The two front tires are quite new (just 7-8k miles) on it. But I have never rebalance since I bought them.
Regards,
-AC
Old Apr 12, 2002 | 09:50 AM
phat's Avatar
Regards,
-AC
Either u need your tires balanced or u need a wheel alignment. Look at your tires to see wheather or not your tire wears out unevenly. Make sure that u check the inside portion of the tire because a lot of people overlook it because they only look at the outside portion to the tire. Also, If u get your wheel aligns, make sure that they do allllll 4 wheel alignment. Max only have 4 wheel toe adjustment and it is really easy, but bad mechanism will take advantage of u any way they can.
Those are the only two simple and common problems with front ends. to test other suspension part is kinda hard to do over the net.
Old Apr 12, 2002 | 09:55 AM
phat's Avatar
Regards,
-AC
Front end problems are hard to diagnose because there are a lot of parts working together. From what u are saying, it sound like u either need your tires balanced or u need a wheel alignment. Look at your tires to see wheather or not your tire wears out unevenly. Make sure that u check the inside portion of the tire because a lot of people overlook it because they only look at the outside portion to the tire. Also, If u get your wheel aligns, make sure that they do allllll 4 wheel alignment. Max only have 4 wheel toe adjustment and it is really easy, but bad mechanism will take advantage of u any way they can.
Old Apr 12, 2002 | 11:05 AM
maxmizd27's Avatar
My car vibrated up front and in the steering wheel all the way to Nopi and back last fall. Got the tires re-balanced and all was fine. Already had the cv boots replaced a few years ago, so they were ok.
Old Apr 22, 2002 | 03:12 PM
AC439's Avatar
Fixed.
I just want to reply to the board for a followup.
I finally took my car to Discount Tires for a 4 wheels life time ($24) balancing and this fixed the problem. Glad that this is not other suspension components.
Thanks.
- AC
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
