Installing ST sways?
Im trying to put my rear sway bar in right now, but no directions. Not sure what to put were or those metal plates. Anyone got some pics i could look at or a write up. Thanks for any help
http://www.ee.utulsa.edu/~mblehm/pic...car/sway_bars/
Oh yeah, and upgrade your underbody mounting brackets pronto if you haven't already.
I would get some heavy duty washers welded to the tabs on the rear of the chasis while you're at it. They're the ones the drag links bolt through for the rear bar. Both sides have broken on my car and it's in the shop as we speak getting the right rear bracket re-welded for the second time. The bar is too strong for those thin little stamped brackets and the bolts have a tendancy to pull right through the metal if you hit a nasty bump.
Originally posted by maxmizd27
I would get some heavy duty washers welded to the tabs on the rear of the chasis while you're at it....
It would be a lot simpler for me to go to Home Depot and get some thick washers with the right size hole and get that welded on, instead of scrounging up and cutting some 1/4" angle iron and drilling a hole...
(What's the hole size anyway? Looks like 3/8".)
I have had washers on my stock brackets for 3 1/2 years now and one only now broke again. I think they are fabricating a more substantial reinforcement for the bracket this time instead of just another washer. I haven't had the whole bracket come off. Yet.
BTW Bman, I have a 2K Courtesy FSTB sitting here to try this weekend. Keep your fingers crossed!
Originally posted by amax935
do the front ones break, or just the back ones?
MaxLife17
Jun 27, 2019 01:37 PM
pears
Sep 18, 2015 05:25 AM
catalinvint
Sep 16, 2015 07:48 PM
