Door lock relay
Old Apr 22, 2002 | 12:31 PM
WLVBRIT
Door lock relay
12/92 GXE, 93 model, electrical door locking works only occasionally.
It either works for all 4 doors or it doesn't work at all.
Same effect whether using button/switch or pushing down pop-up door lock control.
I hear a click, so I believe switch/circuit is OK and Relay is the problem.
1. Where is the relay and how do I get to it?
2. Is the relay the most likely cause, given the symptoms?
Thanks in advance for any advice - this is a great site - I wish I'd found it a few years ago!
Old Apr 22, 2002 | 02:02 PM
eric93SE's Avatar
I have not had trouble with mine, but I did have to replace the relay for the window opening circuit. did you do a search on the org yet!!
I'm not sure if the relay for the door lock solenoid is located in the same location, but it is probably under the key pad in the door.
Old Apr 22, 2002 | 02:10 PM
93maxVG's Avatar
I can be almost 100% sure it is your door lock timer. That is exactly what happend to mine, so I did a search. The timer is located underneath your steering column on the right side. It is a little box about the size of 2 decks of cards. Remove the box and pull out the circut board. On the bottom of the board are many small solders. Look for ones that are cracked or "not shiney" anymore. Re-solder those connections. This is how I fixed mine, and how countless of people on this forum have fixed theirs. Good Luck
Old Apr 22, 2002 | 02:13 PM
93maxVG's Avatar
Need more help??? Do a search for "Door Lock Timer" It will give you all of the info you need.
Old Apr 22, 2002 | 05:38 PM
techsx2's Avatar
Re: Door lock relay
well if you do have to replace anything let me know and i will see what i have i am trying to piece mine out techsx2@earthlink.net
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
lrb6805
Sep 24, 2015 05:03 PM
