Quick question on removing belts on 92SE
Hi guys,
I've finally got all my tools and parts ready to change the front crank oil seal on my 92 SE. I have a quick question before I start to do the job.
I know I have to remove all the drive belts and I did them before. But it was done when I drove the two fronts wheel onto the ramp so I can get access from below. Now, replacing the crank seal I need to take the passenger wheel off so I can't drive it up the ramp. If I take the wheel off, then take the plastic fender shield off. Can I remove the belts from the right side of the car instead of from underneath it?
Thanks.
-AC
Thanks.
-AC
Re: Quick question on removing belts on 92SE
Originally posted by AC439
Hi guys,
Thanks.
-AC
Hi guys,
Thanks.
-AC
It is a lot easier to remove the belts from the bottom especially the alt. and the pwr steering belt. Why would u want to use the ramp to work on the crank seal? It is a lot easier using a jack and jack stand for the job that your doing.
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
trungg86
Sep 4, 2015 04:58 AM
