intake manifold
Old May 19, 2002 | 08:39 PM
pearl93max's Avatar
intake manifold
I pulled the lower part of the intake manifold off today...b/wn the plastic air tube and TB...inside it's pretty dirty and black. What can I use to clean it..intake manifold cleaner??? (dumb ?)...just spray into the TB??? Or would it be better to try to take it all apart? I'll have money to get a manual friday...so either just put in your .02 or tell me to shut up and wait!! j/k...Thanx guys
-Blake
Old May 19, 2002 | 11:03 PM
flyry110's Avatar
carb&choke cleaner will work. if you're worried about firing it into your intake, just put it on a rag. . .. .
Old May 19, 2002 | 11:13 PM
Matt93SE's Avatar
STFU n00b!
If you're up to the work, pull the entire manifold off and clean it up.
you can also change the fuel injector hoses while you're in there, and valve cover gaskets too if they're leaking.
Old May 20, 2002 | 12:41 AM
mykizism's Avatar
Re: intake manifold
-Blake
you took apart the dual duct intake thing?
you can use intake cleaner spray it inside that would clean that visual part up a lil bit.
but on the upper intake manifold you`ll never get that clean until you take apart the whole intake assembly.
btw, i saw your car sat night, at the NIO meet. i came late, i guess every one was inside 59 diner eating, i just walked around looked at the turbo'd 240 and other cars and just went to my gf's house
i talked to a 4th genner guy, i forgot his name, but he has a dark green 4th gen max, he complimented me on my bmw lights w/ HID
Old May 20, 2002 | 12:15 PM
pearl93max's Avatar
awsome man..i was looking for you there. Matt...is taking the whole thing a pain. I have all the right tools and know how.
Old May 20, 2002 | 12:50 PM
blackandwhite's Avatar
To them I'm like an idol
Re: Re: intake manifold
Yeah man, I was looking for you too, so you could look at my control arm issue, but I had to leave around 8:30.
Matt93SE's Avatar
STFU n00b!
not too difficult at all. it's an afternoon job to do everything and clean it up correctly.
while you're in there, take some small grinder stones on a drill and clean up the casting flash inside the manifold. there's not a ton, but there is some in there.
a few weeks ago, we started about 10am and changed tranny fluid, removed/cleaned/ground/replaced intake manifold, changed spark plugs, plug wires, valve cover gaskets, all vacuum hoses, and fuel lines... took us about 8 hours for everything, including 2 trips to the store.
Old May 20, 2002 | 01:12 PM
pearl93max's Avatar
how much cash for everything...minus the plugs, wires and tranny fluid...already done?
I just got done pulling the TB off and cleaned what I could and replaced PVC...Just by that the car runs better and throttle response is better. I'm off thurs and fri....i'm gonna do everything you said then...if it's not too
exspensive.
Anything else I should get while i'm shopping...o2 sensor, ???? prolly still factory
-blake
Old May 20, 2002 | 05:52 PM
mykizism's Avatar
Re: Re: Re: intake manifold
yah sorry, i wanted to show up earlier, but i couldnt fit that into my schedule, i got there like at 9 something.
But still if you have time this week you can give me an email and we can find a time where we can meet and take a look at your control arm.
tomarrow (tuesday) im off from work all day. so if tomarrow is good let me know
Old May 24, 2002 | 11:09 PM
mykizism's Avatar
here some pics of my intake manifold when i ported and polished it\
http://www.picturetrail.com/mykizism/853565
Old May 25, 2002 | 05:54 PM
Maximajism94se's Avatar
i did my rear valve cover gasket about a month or more ago, i had no previous experience w/ car stuff excpet basic routine stuff, and it took me 8 hrs or so 4 everything, i just took off the intake, cleaned the tb, changed the gasket and put it all back together...fun it was...not to hard or anything, just time consuming cause there's lotsa bolts and crap to label and keep track of
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
