how do i remove my tail lights
Step 1...remove idea from your head about clearing tails...
Step 2...repeat step 1..
ok if you really need to know...
you have to remve the plastic strip that lines the top of the tunk between the tails...then pull back gray cloth covering behind the tails...then there's 4 screws/bolts...remove them and pry tails out
ok..
un bult about 4 or 5 nuts in the trunk behind each light housing.. after that you have to get a blowdryer.. or heatgun the blowdryer works fine.. now you have to heat up all the black tar-like stuff that holds then in place.. then when its all nice and hot/mushy, you just have'ta pull with all your might!.. it will slide out... that tar suff will stick to every thing and won't come off the paints.. so look out... PEACE!
The Frye
09-02-2021 11:03 AM
Maxima30
09-07-2015 06:13 PM
