red conector
Old May 31, 2002 | 09:55 PM
jaredb03's Avatar
red conector
the red conector by the fuel pressure regulator (on a VE) is that the colant temp sensor, or temp switch? also what is the black conector right next to it? thanks in advance
Old May 31, 2002 | 11:47 PM
Matt93SE's Avatar
STFU n00b!
there's actually TWO coolant temp sensors for the engine. the black one runs the gauge inside the car, the red one feeds the computer information.
disconnect the red one while the engine is running, and the fans will come on about 5 sec later.
Old Jun 1, 2002 | 08:13 AM
jaredb03's Avatar
well i asked cause i pulled the codes and came up with a 13, and a 13 is the engine temp sensor, so is that the same thing as the coolant temp sensor (red conector)? also where is the temperature switch?
Old Jun 1, 2002 | 09:05 AM
Matt93SE's Avatar
STFU n00b!
temp switch? I dunno.
but yes, the red guy is the coolant/engine temp sensor. try cleaning the connections and see what happens. I don't think they're too much to replace, but it's worth trying to clean first.
Old Sep 15, 2002 | 04:28 PM
thacker's Avatar
IAT intake air temperature
has anybody heard of this i heard you could do some mods to this and get about 15-20 more hp?somebody help
Old Sep 15, 2002 | 09:39 PM
Matt93SE's Avatar
STFU n00b!
yeah... you might be able to.... on a car that actually has an IAT. 3rd gens are OBD-I, not OBD-II.
aw11power
Oct 10, 2021 04:57 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
bigfrank
Oct 1, 2015 12:51 PM
wiseguy6199
18
Oct 1, 2015 12:28 AM
