oil on plugs
Old Jun 17, 2002 | 04:33 PM
pearl93max's Avatar
oil on plugs
I checked my spark plugs today and they all look ok...worn, but good. Except for the #5 and #6 cylinders which have some oil on the plugs
_ x x ...on the x's.
_ _ _
I'm gonna replace them friday, but I wanted to know if I had a problem with the engine that I should check out soon. The oil is only on the treaded part of the plug, not the head and tip and the tips are ashy white and clean. Thanks for the help.
-Blake
Old Jun 17, 2002 | 04:36 PM
naijai's Avatar
Re: oil on plugs
_ _ _
-Blake
yu either have a gasket leak or yur piston rings there is also the valve seals are worn out so either way yur engine need work cause if oil is getting there yu need work
Old Jun 17, 2002 | 04:38 PM
pearl93max's Avatar
as in try replacing the head gasket too?
Old Jun 17, 2002 | 05:06 PM
davis4005's Avatar
The head gasket is not a simple job, make sure what it is before you do anything. Is the oil on the threads or the actual plug?
Old Jun 17, 2002 | 05:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: oil on plugs
_ _ _
-Blake
oil or gas?
make sure you know what's on it.
gas = leaky injector
oil = blown rings, blown head gasket, blown valve seals
Old Jun 17, 2002 | 05:17 PM
pearl93max's Avatar
it's brown oil....I know the diff between the 2. It's on the treads and gasket of the plugs on the #5 and #6 cylinders. Not trace of oil on the head and tip of the plugs or where the wires plug up either.
Old Jun 17, 2002 | 05:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
ok smart guy..guess it's time for a compression check.
good luck.
Old Jun 17, 2002 | 05:26 PM
pearl93max's Avatar
not trying to be smart..I just know the diff, that's all. Thanks for the help and I'll get the compression checked and look at all my seals tomorrow.
Old Jun 17, 2002 | 05:28 PM
DanNY's Avatar
Ad·min·is·tra·tor
make sure you/they can determine if it's the rings or the valves.
Old Jun 17, 2002 | 05:33 PM
pearl93max's Avatar
will do...I dunno if i'll end up doing it or just get someone to check it out. Just trying to get everything fixed I can. Next thing is KS...either clean the connectors or just replace it. Track times suxd last night...best was 17.1 @ 79mph...so, I'd determined to find out what's wrong with it and fix it.
Old Jun 18, 2002 | 12:10 AM
tilt's Avatar
Re: oil on plugs
The firewall side cylinders are odd numbers, 1 3 5. You say only the threads have oil... is it possible that you just spilled some oil over the spark plugs? Also if the tips are white, I believe it means you are running lean on fuel.
_ _ _
-Blake
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
trsandrew
Oct 25, 2015 02:47 PM
