can you put a turbo in from a 300zx into a max ?
Old Jun 21, 2002 | 10:23 PM
pmb1985's Avatar
if you get a 300zx same year, same engine, could you use the turbo in the max? just bringing it up because of the locked one that i read.
Old Jun 21, 2002 | 10:31 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: can you put a turbo in from a 300zx into a max ?
you don't need a 300zx turbo per sae....any turbo will work!
Old Jun 21, 2002 | 10:43 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: can you put a turbo in from a 300zx into a max ?
ANY turbo? I wander how long it would take to spool up one of those monster turbos like on a big rig.
sorry its late and I am tired and delerious
Old Jun 21, 2002 | 10:48 PM
mykizism's Avatar
Re: Re: Re: can you put a turbo in from a 300zx into a max ?
those inline 6 turbo diesel, 4 wheel tow trucks use the same size turbo as the z31
Maxima_Van_WA's Avatar
Hell for that matter, call up NASA. They're turbo impellers are machined one piece titanium. I know they can empty an olypic size swimming pool in about 30 seconds or so. That ought to get ya goin once it spools up (FYI liquid nitrogen will help it spool a bit faster than your typical premium unleaded).
Old Jun 21, 2002 | 10:55 PM
Dummy's Avatar
here ya go!
http://www.turbointegra.blike.com/ho.../hugeturbo.jpg
Old Jun 21, 2002 | 11:00 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Re: can you put a turbo in from a 300zx into a max ?
I saw one when I was working on a printer at Tri State Mack (a Mack dealer here) that was huge and wouldn't even fit under the hood of a max or any other import for that matter...thats what I was refering to...man cant you read my mind
Old Jun 21, 2002 | 11:09 PM
mykizism's Avatar
Re: Re: Re: Re: Re: can you put a turbo in from a 300zx into a max ?
naw i knew what you were talking about. i was just thinking about that tow truck i saw the other day.. thats all.
Old Jun 22, 2002 | 05:33 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
This thread sucks
Old Jun 22, 2002 | 05:35 AM
Pervis Anathema's Avatar
Originally posted by Chris91SE
This thread sucks
Hey guys, can I put a viper engine in my max? I wanna keep it front wheel drive if possible. That would be so bling bling.
Old Jun 22, 2002 | 07:21 AM
Dummy's Avatar
from the same year no, unless its 89.... if you have a vg max you can swap the turbo parts like injectors, manifold, turbo, and oil lines from the 84-89 300zx's but you would need to get your ecu programmed by JWT and fabricate charge piping and a downpipe... you could also also swap in the whole motor with a fwd tranny and fabricate a downpipe....
Old Jun 22, 2002 | 07:43 AM
Sudesh's Avatar
they only way to bling in a max is to paint your stock wheels black.
Old Jun 22, 2002 | 12:33 PM
mtcookson's Avatar
yeah, those NASA one's are pretty cool. they put spin up to 1 million rpm and threw out tons of air but i can't remember how much. the one i saw was like.. no bigger than your arm or smaller even.
Old Jun 22, 2002 | 02:11 PM
keener's Avatar
you will need more than just the turbo. you also need to get the 300 injectors and then get the fuel map on your ecu reprogrammed to compensate for increased fuel demand at boost pressures. Good luck. Might also want to consider a one stage colder plug.
Old Jun 22, 2002 | 02:24 PM
MaxManMo420's Avatar
Thats what my turbo looks like.
Originally posted by Dummy
here ya go!
Old Jun 22, 2002 | 07:22 PM
mtcookson's Avatar
well... you could always do what i did to my friend's acura integra instead of trying to build up the engine.
http://www.paylessfreight.com/integra.jpg
Old Jun 22, 2002 | 07:41 PM
DA-MAX's Avatar
not necessarily true....you can run low boost without upgraded ECU, injectors, etc.....a simple FMU and boost metered ignition will do fine!!
Old Jun 22, 2002 | 08:27 PM
DanNY's Avatar
Ad·min·is·tra·tor
well i would say injectors are not 100% necessary..but with the stock injectors..it's hit or miss. u might have a injector fail during a WOT run and boom...cooked motor...so for good insurance use at least new/rebuild/reman injectors if not running the Z31/Z32 injectors.
Cotozic
Jun 28, 2017 08:01 PM
paulpearl
Sep 2, 2015 07:50 AM
Mcnabb34
Aug 11, 2015 08:45 PM
sc10692
Aug 9, 2015 09:37 AM
