Need help getting air out of coolong system
Old Jun 25, 2002 | 08:21 AM
GOLDENGIANT's Avatar
Hey , I just changed the water pump, hoses, ect. Now I'm having a major problem getting air out of the system. The car over heats after awhile, and the upper radiator hose is real hot, while the lower one is cool. Please help!!
Old Jun 25, 2002 | 08:51 AM
Damion's Avatar
Re: Need help getting air out of coolong system
You can let the car idle with the rad cap off and the air should come out after 10 or 15 minutes if not try opening the release bolt on top of your intake manifold
Old Jun 25, 2002 | 09:20 AM
tilt's Avatar
There is a bleeder hole next to the pcv valve. Just unscrew the 10mm? nut and let the motor run until there are no more bubbles.
Old Jun 25, 2002 | 10:24 AM
male's Avatar
I read that elevating the front end of the car 14" or so will help alot.
Old Jun 25, 2002 | 10:35 AM
Terry28's Avatar
does the temperature gauge moves to hot??
Old Jun 25, 2002 | 11:12 AM
THANKS!!! IT WORKED
DJLAX152
May 4, 2021 11:46 AM
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
