stock cd player and bose question
Old Jul 3, 2002 | 06:52 PM
Laly's Avatar
i just received a stock cd player from a fellow member. well i tried to install it and everything but the thick black wire that looks like the antenna wire does not fit. it has about 7 prongs in ti and the bose headunit has a space for a 5 prong wire. i have no sound going to the bose headunit. can anybody with a stock cd player help me with this. maybe someone can check the back of their old headunit and see how many holes are in the back for this wire. thanks
Old Jul 3, 2002 | 07:19 PM
D-sta's Avatar
i don't think our cars can use the 7 prong plug since we use the 5 prong on the stock bose radio. In order for it to work I think you need to get the one manufactured by SONY, the sony unit has 5 prongs.
Old Jul 3, 2002 | 08:17 PM
klymkow's Avatar
Re: stock cd player and bose question
I believe the headunits changed to the 8 pin din plugs in 93. They still looked the same so you have to look at the model numbers in order to tell the difference. I think the model numbers are: 1992 is PN-9481D and 1993 is PN-9700.
As far as I know there are no adapters to convert from one to the other. I never tried to make an adapter, but I do have the pinouts if you're interested.
Tim
Old Jul 4, 2002 | 12:52 PM
Laly's Avatar
well i guess im screwed then,
tim, if you could get me those pinouts that would be great. maybe me and a friend could try and make an adapter.
otherwise, does anyone with a factory CD player from a 92 and before for sale. or maybe someone has a factory bose headunit from a 93 and above for a sale that works well
thanks
Laly
Old Jul 6, 2002 | 06:52 AM
klymkow's Avatar
thanks
Laly
Here you go:
5-Pin:
Pin 1 = On Signal (CD->Headunit)
Pin 2 = On Signal (Headunit->CD)
Pin 3 = Signal Ground
Pin 4 = Left Channel Input
Pin 5 = Right Channel Input
(info from 89-90 unit PN-92101-A; same for other 5 pin headunits)
8-Pin:
Pin 1 = CD-On Signal Input
Pin 2 = Headunit -On Signal Output
Pin 3 = Not Used
Pin 4 = Left Channel Input (+)
Pin 5 = Right Channel Input (+)
Pin 6 = Left Channel Input (-)
Pin 7 = Right Channel Input (+)
Pin 8 = Not Used
(info from 92-93 unit PN-9700D; same for other 8 pin headunits)
Tim
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
