Rewiring Sunroof
Old Jul 7, 2002 | 03:29 PM
NCSUmax's Avatar
Rewiring Sunroof
I was driving today and had a drink in one hand (lack of cupholder) and the steering wheel in the other, and I wanted to open the sunroof. I realized how great it would be if we had one touch buttons. So you can just press it once, and the sunroof opens fully, instead of holding the button down. I think it would be pretty easy to wire up a circuit to do this. Has anyone else done this already? If not I think I may post the results and a little tutorial how to do it.
Old Jul 7, 2002 | 04:03 PM
DaBoxSE's Avatar
I was thinking the exact same think the other day. I always wished our sunroofs had that option like the 4th and 5th gens. I'd like to how your results are and I will try to tackle it myself sometime.
Old Jul 7, 2002 | 05:26 PM
Jeff91SE's Avatar
Craig Brace hasnt tried this already? Wow.
Old Jul 7, 2002 | 06:27 PM
«§»Craig B«§»'s Avatar
actually, I looked into this a long time ago; if it were a simple rewire, I would have had it on my page by now
there isn't a "easy" way that would work without adding a few components here and there
I'd thought of a couple things, but to do it the right way, try one of those auto up/down window modules. I think they have them at www.autoloc.com or something like that and I've seen them on ebay before too. You could use it on the sunroof instead of the window.
Wiring up to the switch is a little bit of a pain but doable.
I never did it but I know some 4th gen guys have worked on it so search their forums for more info
good luck
Old Jul 7, 2002 | 07:38 PM
NCSUmax's Avatar
When I say simple, I mean for someone fairly comfortable with electronics, but I'll let ya know how it goes.
Old Jul 7, 2002 | 07:49 PM
when I say easy, I mean for most people on .org that dont know much at all about electronics but without extra parts, it's not really feasible
I didn't realize you were looking to design something yourself. You could make a very simple RC circuit to just make a simple delay, or you could make a 555 timer which would probably be a better idea. But then you probably also want something to sense the current so it doesn't go too far and wear out the motor. Opening the roof seems like it could be done allright, closing would require 2 steps because of the auto-stop which is built into the motor (the FSM strongly suggests NOT taking apart the sunroof motor so I'm not sure how it's worked in there) but it's still definitely doable.
From the discussions of the 4th gen guys and doing a little bit of thinking myself, it's almost better to just buy the window module for $10-20 or whatever it is and use that.
But if you're gonna try to rig something up yourself, that's great. Let us know how it goes.
Good luck
Old Jul 7, 2002 | 08:02 PM
NCSUmax's Avatar
Yeah I'm thinking taking apart the motor is a bad idea but one idea I do have is a trip switch of sorts. If I just run a timer circuit then I'd have to judge the time, and it seems to pull back slower when it is colder. If I use a trip switch I can run the circuit untill it opens fully, trips a switch on the track maybe? and cuts the circuit. Another thing I have noticed is that the WIN function on the keyless entry controls the sunroof. Im gonna try to rig my remote keyless entry into that circuit somehow, I know that has been done though. So tomorrow a trip to radio shack and some time with my multimeter will be spent... lets hope it works.
Old Jul 7, 2002 | 08:37 PM
yeah, that might work using a few sensors here and there along the track
I didn't realize you had a GXE, you might be able to tap into the stock keyless entry like you mentioned. I have a SE so I haven't had a chance to ever play with one of those. It's to the right of the glove box under the dash (you probably already knew that, but just in case).
let us know how it goes
Old Jul 7, 2002 | 09:21 PM
darrick's Avatar
Dallas Nissan Enthusiast
yes,yes
this would be a nice little mod,let us know
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
