help programing keyless remote
Old Sep 29, 2009 | 03:14 PM
MR96GLE's Avatar
so i just got a keyless remote for my 96 gle and when i went to program it i didnt put the key in acc so i messed it up...so i try again and now i cant get the hazards to flash when i put the key in 6 times...i have tried like 15 times and nothing has happened so i put the key in the acc position and hold the lock button for 3 seconds and they hazards blink twice but i still cant do anything with the remote...any help would be great
Old Sep 29, 2009 | 03:17 PM
NevadaJack_9's Avatar
Wrong forum
Old Sep 29, 2009 | 03:20 PM
TurboA32's Avatar
wrong spot to post this but just disconnect the negative side of the battery and connect it back and try your program again should work.
Old Sep 29, 2009 | 04:23 PM
Teaner's Avatar
2003 Nisan Maxima
To program the remote(s) follow this procedure.
1. Unlock all doors and get in car.
2. Close and lock all doors with power door lock switch on driver's door.
3. Insert the ignition key and completely remove it at least 6 times
within 10 seconds. The hazard warning lamps (both turn signals) will
then flash twice and all previous codes will be cleared.
4. Turn ignition key to "ACC" position.
5. Push any button on the new remote control key fob once. At this time,
the car learns the new ID code. The hazard warning lamps (both turn
signals) will then flash twice.
If you are programming just one remote, go to step 10.
If you need to activate additional remote controllers, continue with Step 6.
6. Manually unlock the driver's door only then lock again with door lock
7. Push lock button on the additional remote controller once.
8. Hazard warning lamps (both turn signals) will then flash twice and
additional remote is programmed.
9. For additional remotes, go back to step 6.
10. When done, open the driver's door to exit programming state.
NOTE: A maximum of 4 remotes can be programmed to any ONE car.
Showing results 1 to 9 of 9
Search took 0.02 seconds
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
