What to clean the inside of the engine block with?
Old Jul 11, 2002 | 06:04 PM
240sxxx's Avatar
me and a friend took off the top of the crankcase on his 96' max... it looks pretty dirty inside it .....
if you guys dont know what part of engine I am talking about it is the metal "engine cover" right above the camshafts ..... and I dont mean the spark plug cover on the outside ......
also any specific things that have to be delt with carefully when putting this engone cover back???
Old Jul 11, 2002 | 09:16 PM
240sxxx's Avatar
anyone.......?
Old Jul 11, 2002 | 10:12 PM
xHypex's Avatar
Re: What to clean the inside of the engine block with?
You are talking about the valve cover. If you want to clean it you can do so with an engine degreaser, but be sure to wash it all off and let it dry before putting it back on.
When you put it back on be sure you get the gasket in the right place so you don't leak any oil in the future. Tighten the nuts in cross patterns as well (i.e. left bottom, right top, left top, right bottom, etc.).
I've taken mine off twice without any problems, but if you take it off too much you should probably replace the gasket.
-hype
Old Jul 12, 2002 | 06:31 AM
1MAX2NV's Avatar
Use engine degreaser for the light residue first. Brush it with a tooth brush. Rinse off and let it dry. Then use carb cleaner on the caked on residue second. Carb cleaner works better when the part is dry. You will need to use the whole can if the motor has more than 80K miles.
Here's a Honda valve cover I cleaned with the above method.
http://photos.imageevent.com/1max2nv...e/DCP00838.JPG
Old Jul 12, 2002 | 08:13 AM
pblaze's Avatar
The older I get, the more I sound like my father. Why the heck do you want to "clean the inside of the engine block"? In the first place, you've pulled off the valve cover. You're looking at the top of the cylinder head. There's probably a coating of brown varnish on everything except the cam lobes and lifter faces. Leave it there. It's not hurting anything. If any real dirt has gotten in there while the cover has been off, you can get it out using a clean rag soaked with engine oil. Assuming, of course that the cams and lifters are still absolutely clean. DO NOT use degreaser or carb cleaner anywhere near the valve train components. You'll strip the oil off them and dilute the oil in the crank case.
As far as putting it back together, when you go buy the new valve cover gasket, buy a Haynes manual for the car. Follow the torquing procedure if there is one. Usually you start in the center and work your way out in a cross pattern.
Old Jul 12, 2002 | 08:22 AM
240sxxx's Avatar
thanx for the help guys....
we have already bought a haynes manual like a year ago so we new what we were doing ..... hmm I never knew you could reuse the gasket.... got a new one too
Old Jul 12, 2002 | 09:53 AM
xHypex's Avatar
It's not advisable to resuse gaskets, but it can be done. If it causes problems down the line it's time for a new one.
-hype
Old Jul 12, 2002 | 10:05 AM
RAZER's Avatar
So do it or not man???????
Old Jul 12, 2002 | 12:48 PM
1MAX2NV's Avatar
Well...he's asking about the valve cover so "YES" he can take that part off and clean it. If he wants to clean the valve train, I would assume he would take the head off.
MAXSE5SPD
Sep 17, 2022 04:00 AM
conansriver
Sep 3, 2015 06:38 AM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
niZ
Aug 7, 2015 10:18 PM
