Fog Bulb Install
Old Jul 12, 2002 | 11:26 AM
MaxSport730's Avatar
Fog Bulb Install
I did a search already
how do i replace the foglight bulbs (h3's)...do i get under the car or do the lenses pop out?
thanks for your help
adrian
Old Jul 12, 2002 | 11:54 AM
kmax's Avatar
Remove the foglight. Remove the black plastic screw on the black plastic trim piece. Next, there are two bolts to remove. If I remember they are 10 millimeter hex with a phillips slot. After taking out the two bolts the light will come out. You can then disconnect the harness and replace the bulb.
Good luck.
Old Jul 12, 2002 | 11:58 AM
thanks alot...i'll give it a shot
Old Jul 12, 2002 | 12:33 PM
breaux124's Avatar
Instructions with Pics
http://integra.vtec.net/geeser/megamax/foglight.html
Old Dec 21, 2002 | 04:04 PM
Gary95's Avatar
remove the foglight?? why?
That link seems to be dead (as of 12/21/2002), but the site appears to be up. The main page (integra.vtec.net) comes up with a blank page though.
If you have a 95 or 96, you won't have to remove the foglight in order to replace the bulb. You can get access to the back of the foglight housing once you remove the splash guard (connected to the fender guard). You just twist and pull off the retaining cap and then release the wire retaining clip to remove the bulb. Replacing it isn't as easy as the 9004, because it is so small. Definitely jack up the front side of the car so that you have room to work.
I would have expected this procedure to work for the later 4th gen, as the light is in the same location (just shaped a little differently). But maybe that's not the case?
Old Dec 21, 2002 | 04:19 PM
Bad97MaxSE's Avatar
The car manual helps too
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
Johnny9595
Sep 3, 2015 05:18 AM
