Please help diagnose electrical problem, car will not start
Whenever I go to start my car fuse #33 (start signal) blows. This fuse is located in the fuse box located on the bottom of the driver side dash. Looking at the wiring diagram for it I can see the wire starts at the ignition switch, then passes though the fuse box, then thought the theft warning relay, then though the clutch interlock relay, and then to the starter motor, or at least thats how its appears to me. Also if you turn the key to the start position without depressing the clutch down most of the time it wont blow the fuse, but occasionally it will, while if the clutch is pressed down then it always blows. I really want to avoid bringing it to a dealer, but im not experienced with electronic systems, if someone could point me in the right direction as far as what to test and how test it would be greatly appreciated.
There is an interlock switch that is operated by depressing the clutch, with you able to recreate the problem or not if you do not push the clutch all the way in, it sounds like its the switch or possibly the clutch pedal asembly shorting out. Should be easy to check with a multi meter.I checked the NISSAN FSM, the interlock switch is attached to same bracket as the clutch pedal is. It looks like access is underneath the dash.
Be well!!!!
Be well!!!!
Well still no luck fixing the problem,I did test the interlock switch but that was not the problem. Now the fuse for the wipers blows as well. I think im gonna just bring it to nissan unless someone has any last minute ideas I should try first.
As a long shot I would check electrical grounds. If 1 is falling it sometimes finds really weird paths to complete the circuit. I would clean all of them in the engine compartment that I could find and see what happens! It sounds like you have a bad ground, broken ground wire, etc.
Be well!!!!
Be well!!!!
Be well!!!!
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MAXSE5SPD
08-23-2015 12:06 PM
