loose strut tower bolt
Old Jul 17, 2002 | 09:04 PM
JeepRage's Avatar
I just lowered my car, new springs and struts... my problem is i cant tigheten down the bolt on the strut that holds the spring in place on my driver's side, the strut shaft spins with the bolt. i need a few more revolutions to snug it up... any suggestions?? what did the rest of you do??
Old Jul 18, 2002 | 05:49 AM
njmaxseltd's Avatar
The hole in the strut mount isn't round. Take a look at the threads on the strut. There's a grove down the side. That grove holds the piston shaft from turning while your tightening things up. It sounds like your strut mount is worn out and the oval shaped hole is now round allowing the strut shaft to spin.
You have 2 options:
1) Use an air gun and carefully give a few pulses. That will definately spin the nut fast enough to snug it down a bit. Stop by your local gas station and let the mechanic do it for ya. Tip him a 20.
2) Replace the upper strut mount. This is the correct way to fix your problem.
Old Jul 18, 2002 | 06:21 AM
Dreizehn's Avatar
I have the Stillen camber plates and they don't have the mentioned groove like stock, so I ran into the same problem. I took a pair of vice grip plyers and a leather shami and had to grab the strut shaft the best I could, then crank on the top. It's a hell of a lot easier if you have someone to help...
Hope this helps...
Old Jul 18, 2002 | 06:27 AM
JeepRage's Avatar
You have 2 options:
Thanks for the part advice... makes total sense now that i think about it. looks like im off to the nissan dealer
Old Jul 18, 2002 | 06:29 AM
njmaxseltd's Avatar
Hope this helps...
Great idea! Just be V E R Y carefull that you don't damage the piston shaft. The leather shami is a great idea, might wanna try to get some thicker rubber too if you can. You shouldn't have to grab the shaft that hard. The bolt only requires about 50 ft lbs of torque to snug it up.
Old Jul 18, 2002 | 06:30 AM
JeepRage's Avatar
Hope this helps...
that was my other choice... i picked up the craftsman strap wrench last night, thinking i might use it. not sure if i should, or just get the right part... thanks for the advice guys. i'll let you know what i do/if it works
Old Jul 18, 2002 | 07:10 AM
iwannabmw's Avatar
I used the vice grip trick as well. Try to grab the tip of the shaft above the bolt, it might barely fit, but that way you won't damage the part of the shaft that slide up and down.
BTW, you made me look it up
The thing that says Boost sensor is the absolute pressure sensor. According to the book, it is connected to the MAP/Baro switch solenoid valve by a hose. The sensor detects ambient barometric pressure and intake manifold pressure, and sends a voltage signal to the ECM. As pressure increases, voltage rises. The absolute pressure sensor is not used to control the engine system. It is only used for on-board diagnosis.
Now we know
Old Jul 18, 2002 | 07:59 AM
JeepRage's Avatar
Now we know
HAHA, DAMN... thanks, i knew you were the one to ask i cant get the vice-grip to grab enough... im heading to the dealer in a few to pick up the new mount
D Mason
Jun 21, 2016 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
