Eibach Pro-Kit Springs Question
Old 07-18-2002, 09:24 AM
maxwillden's Avatar
I have a set of Eibach Pro-Kit springs installed on my Max. They were installed by the previous owner, so I don't know much about 'em. I was wondering though, if anyone else that has them has a problem with a lower rear end ride height than the front... Or in other words, my A$$ sits too low to the ground, and the front end looks like it is ready for a flood... Maybe a 2-3" difference...
By the way, I have only a 30lb speaker box in the trunk, but that weight is offset by the fact that I don't carry a spare tire.
maxwillden is offline
Old 07-18-2002, 09:32 AM
VQdriver's Avatar
Re: Eibach Pro-Kit Springs Question
the rears might have been installed upside down. you can check really quick by looking underneath. the tighter progressive coils should be to the bottom of the shock and the lettering "eibach" should be right side up.
VQdriver is offline
tmkforever's Avatar
I've got the Pro Kit and I'm really happy with them. The drop is just right for me and its very even and level. I haven't had any problems like that. Maybe you need to adjust your rear shocks if you can, or cut your bump stops? Just a thought.
-Jon
tmkforever is offline
Old 07-18-2002, 09:33 AM
hokiemax's Avatar
I've got eibachs too. The lower end should not be sitting 2-3" lower than the front. That doesnt sound right with ANY springs. Are you sure your rear is really that much lower? If so, then the previous owner might have cut off a coil or 2.
hokiemax is offline
Old 07-18-2002, 09:45 AM
RIP '98 Maxima SE
BlackCat's Avatar
2" - 3" drop doesn't sound right...I think I have a 1 3/4 finger gap in the back and 2 finger gap in the front.
BlackCat is offline
Old 07-18-2002, 09:52 AM
hokiemax's Avatar
The tighter coils goes on TOP. Dont look at the lettering. The tighter coils need to go on top, not bottom.
hokiemax is offline
Old 07-18-2002, 09:54 AM
VQdriver's Avatar
Re: Re: Eibach Pro-Kit Springs Question
-Jon
cutting bump stops shouldn't change the ride height. eibach doesn't recommend you cut the rears anyway.
VQdriver is offline
Old 07-18-2002, 10:02 AM
maxwillden's Avatar
Re: Re: Re: Eibach Pro-Kit Springs Question
I don't think it's really 2-3"... It just looks that way most of the time. I'll check everyones recommendations. Thanks
Old 07-18-2002, 10:16 AM
VQdriver's Avatar
Re: Re: Re: Re: Eibach Pro-Kit Springs Question
when i reinstalled them right side up, the rear end rose a little to match the front. it still sits just a tad lower, but not dramatically lower. i've seen someone with "newer" eibachs. their ride looked slammed. does anyone know FOR SURE if eibach made newer springs which have a more dramatic drop?
VQdriver is offline
Old 07-18-2002, 11:56 AM
98fiveSpeed's Avatar
I've got eibachs and tokicos.. The front is a little higher than the back. And the whole car feels to high for me. I am thinking about cutting a coil from each spring up front and atleast 1/2 from the back.. I have 18's and the car looks high.. Got these a long time ago and if cutting the springs ****s up my ride then I'll prolly just change the springs and shocks to get something that actually lowers this car..
98fiveSpeed is offline
Old 07-18-2002, 12:28 PM
maxwillden's Avatar
Same setup, same problem... I wonder why? Hmmm...
Old 07-18-2002, 12:41 PM
hmm.. has anyone tried cutting springs on a eibach+tokico setup? I think this was the very first setup that stillen started selling?
Old 07-18-2002, 12:54 PM
maxwillden's Avatar
I'm interested in knowing this as well... I called Eibach and asked them about this. They told me to check if the guy who installed them originally cut the front bump stops. Is there a way to check this by looking at the setup? He claims that the front bump stops need to be cut in order for the springs to ride correctly, and for the ride height to be level.
BkGreen97
04-02-2016 05:47 AM
imported_Nismo_max
02-17-2016 03:39 AM
pears
09-18-2015 05:25 AM
Stagnet04
09-13-2015 09:32 PM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: Eibach Pro-Kit Springs Question
