Appropriate voltage for Intake Air Temp. Sensor
Hey all,
My MIL recently came on a few days after I cleaned out my throttle body (oh man, it was dirty). The code thrown was 0401 (intake air temp. sensor). Now, I took out my Haynes manual and tested the sensor myself... the thermistor appears to be working just fine according to the specs given in the manual. However, Haynes says that the sensor should be receiving 5.0 volts, and I measured it at a consistent 4.85V. Is this what's causing the error? I can't think of anything else it could be. I was actually getting this code about a month ago, so I brought it in and ended up having a new Aux. Air Control Valve put in (and now I'm wondering if that was really necessary...)
Anyway, is 4.85V close enough, or should it really be 5V? If it should be 5V, does that mean I need a new ECU?? If someone could check the voltage to their (working) sensor and let me know the result, I would really appreciate it.
Thanks!
Thanks!
Originally posted by 1MAX2NV
Intake air temp Voltage Resistance
14F 4.4 7.0 - 11.4
68F 3.5 2.1 - 2.9
176F 1.23 .027 - 0.38
14F 4.4 7.0 - 11.4
68F 3.5 2.1 - 2.9
Thanks...
Doug
