valve body or torque converter
i am running n/a and plan on staying that way for a little while. I heard from several members that you shouldn't get the vb mod, because of no differences in performance, would a beefed up torque converter make a more noticable difference in performance. I would like to do what i can to make my auto i30 move like a 5-speed. all input would be helpful in my decision.
Re: valve body or torque converter
Re: Re: valve body or torque converter
Originally posted by Chino
TCU controller so that you don't find yourself in 3rd gear doing 15 mph, and the vb mod for harder/quicker shifting. After these two you'll ask yourself. Who needs a 5-speed?
Re: Re: Re: valve body or torque converter
what exactly is a tcu controller, and I bet it is expensive??
Originally posted by maxroadrage
where could you find a tcu controller?
so in essence i could pay 550 for the tcu, and at least 500 for vb mod, 5-speed conversion would run like 2000. tough choice. what do you all think???? my car has 71k and it is a 1996. tranny is still fine.
cai, y-pipe, fstb, rsb, agx ajustables, eibach prokit, 18's with 235/40/18 kumhos
I couldn't fix your brakes, so I made your horn louder
![](https://maxima.org/forums/images/smilies/support.gif)
well that price for conversion is variable....... check craig mack's post.... he did it all for 1200....... i guees ur maybe factoring labor in there 2? For 1000, it's much more worth getting the swap done.
If you are planning on going a lot faster in the future, even the torque convertor won't help much. I am doing a 1.8 60' now with just the above and don't think the torque convertor would help that much although I am guessing. If you are going to stay N/A and dont plan on going any quicker than high 13's or low 14's the torque convertor will make a much greater difference.
The reason I say that is that as soon as I come out of the hole I hit the juice ie like 2500 and it rips like crazy so a TC wouldn't help much.
Originally posted by Jime
I would do the drop resistor mod, its much faster shifing than the VB mod anyway and go with the torque convertor.
I HAVE NEVER HEARD OF A DROP RESISTER MOD, IS IT LIKE THE VB MOD?????? BY THE WAY TO ALL WHO RESPONDED, I DONT LIKE THE IDEA OF HAVING SOMEONE SWAP MY TRANNY FOR A 5-SPEED, TOO RISKY, AND I CANT HAVE MY CAR DOWN LIKE AT ALL. WHO MAKES THIS MOD??
http://bgarner.tripod.com/1995nissanmaxima/id3.html
Check here it makes the trans shift a full line pressure I have used it for over 6 months now at the track. Its a bit too harsh for regular driving but for the track its the only way to go for an auto. Much faster shifting than the VB Mod.
BTW ur caps is stuck.
I've unhooked the drop resister in a VE auto. For normal driving, it SUCKED. Probably very hard on the tranny the way it just banged into the next gear. At heavy throttle it was okay.
Don's VB modification is MUCH more involved than just hooking up a switch to the resistor.
Its been covered in dept before, but since I feel like post whoring I'm going to post the same info again. If you want an auto to be fast off the line, 2 things must be done.
1. Get a higher stall convertor, www.protorque.com supplys L10 with theirs but, protorques are only $395.
2. Buy some 205/50-15 tires to go on some lightweight 15in rims. It might not look the best but your getting the equalvent of a 4.0-4.10 final gear.
Simulation results have shown a 2 tenth drop and 2mph gain in automagics from the gear alone. Now if you were able to really drive the car good and cut 2.0-2.2x 60fts. The auto would run around 14.7-14.9s with I/Y/E.
EDIT: Here is the proof: http://forums.maxima.org/showthread....ight=protorque
http://forums.maxima.org/showthread....ght=205%2F5015
It actually reduced my 1/4 mile time by .3 secs and no one has proven the VB mod can do that.
Until someone can beat my 1.8 60' (proven by timeslip) I think my method is best (unti someone comes up with a better one).
BTW The info for the drop resistor mod come from the site of one of the moderators of this forum.
instantly, so how can you determine the resistor "mod" is faster? Did
you time the speed of the shifts? Also, any Torque Convertor at a higher
flash/stall speed will definitely get you off the line faster, but its
harder on the drivetrain.
Originally posted by Rick2001
I have to tell you, the VB mod is shifting almost
It shifts so fast its no good for everyday driving thats why the vb mod does it at a lower pressure because its permanent you can't turn it on and off like the drop resistor mod.
Besides I get faster 1/4 times doing it and the vb mod doesn't.
A higher stall speed will get you off the line faster granted but the point I was making was that the faster your car is the less difference it makes. ie a 16 sec car will see a big improvement a 13 sec car won't. As soon someone with a high stall speed convertor beat my 1.8 60' I will consider buying one.
Re: Re: Re: Re: valve body or torque converter
How can you say this? You never had this product in your car nor have you every tested this product in your car. Not a valid statement.
Trust me you don't want to ever drive w/ the resistor disconnected around town. It just goes "CLUNK" and it feels like crap. Try it if you don't believe me.
The resistor mode is ghetto IMHO. Don's vb mode works all the time and has very nice full throttle and part throttle shifts(from what I read) I can easily verify this as Ian has the VB mod and I could drive his car anyway I want to.
Re: Re: Re: Re: Re: valve body or torque converter
I already said that its not for driving around town it a racing mod, thats why you hook it up to a switch.
Whether you can call it ghetto or not not really important. The important thing is that it works and does reduce the 1/4 mile time. I have raced with it and without it and it does work exactly like I said it does. (And I can prove it with a timeslip) It also saves the clutches on your transmission because of the faster shift time so much less heat is generated.
Regardless, don't you have a manual transmission?
who did your vb mod, because ive heard a lot of mixed reviews in regards to dons mod
I have heard only positive things about the mod.
If you want to spend $450 to lower your 1/4 time, this probably isn't the mod for you. The jury is still out on whether it will lower your 1/4 time. Some say yes, some say no.
However, it will prolong the life of your tranny. I've driven a car with the VB mod in and I liked it. I would spend the $450 just for the fact that it will prolong the life of the transmission.
Jeff The Moderator...
do you have a manual or automatic?
If automatic... do you have the VB modification?
Everyone and Anyone:
if you get the VB mod, don't you have to put a transmission fluid cooler in? From what I've read, the VB mod makes the A/T shift faster, and since it shifts faster, there's a lot of pressure on the fluid, creating more heat.
I have a 3Gen, and I'm not sure about the later generation Maximas, but the 3Gens have slow shifting transmissions, and that's what I though the VB mod is for... not really for performance but for longevity of the transmission.
What is everyone's take on the VB? Like some people... I don't feel like putting $500 out and not getting anything.
Why not get a torque convertor instead. It has instant gains right off the bat. Combined with shorter gearing, it couldn't be beat. Well until you break an axle
![Cool](https://maxima.org/forums/images/smilies/cool.gif)
Sure the vb mod shifts faster but the drop resistor mod shifts even faster and being switchable gives you the best of both worlds.
You should have a trans cooler if you race regardless of what mods you have.
All the claims of the vb mod making the trans last longer are just that, claims. No can prove a mod makes a trans last longer because you can't prove how long it would have lasted in the first place. Therefore anyone can make great claims like that and no one can prove them wrong. Of course no one can prove them right either.
As I understand it, the reason the A/T are often referred to as being "weak" is becuase they shift so nice and soft. I was given the impression that Nissan purposely designed them to do this to have a bit of "luxury" style to the Maxima.
However, the sweet and soft shifts of the A/T are bad for the gears in the transmission. Maybe not the gear, but I assume something. When the A/T shifts slowly, it's almost like riding the clutch on a manual, while heavy on the gas.
See where I'm going? With a M/T, you can wear out the transmission by doing soft shifts; meaning if you have the clutch pressed in just between the engage and release points. That is what the A/T is doing in a sense. So when the A/T shifts soft like that, it's putting wear on the gears as it shifts from one to another.
What the VB mod is supposed to do is eliminate that soft shift and engage the A/T gears quicker. I know you already know about the VB and stuff like that. I learned about this stuff at www.maximadriver.com.
The reason I am afraid of placing a switch between the plugs for the drop down resistor for the A/T is because the springs on the stock VB is purposely weak for the luxury shift. I don't want to force those springs to shift faster or hard if they weren't made to do that.
I was also wondering. I know that you "unplug" your resistor on the track or wherever only for a short period, but do you have a Tranny Cooler?
LONG post, I know... sorry
I just bought a 7.5" x 12.25" cooler today. I will install it tomorrow. And I will install my valve body this Monday/Tuesday. Then, if everything goes well, I will be at the drag strip Thursday night running my car. And then, I will have before and after times for Don's VB mod... but I will also have a cooler with it. But, I wouldn't imagine the cooler to lower to times noticably by itself.
Originally posted by Stikya
If it's just a resistor, why couldn't it just be swapped for a smaller one, to achieve the same results? (And you wouldn't have to deal w/ an SEL light after each use.)
The resistor only tricks the tranny ecu into making full line pressure shifts. There's no way to control the amount of pressure unless you have a computer piggy back of some kind that could be dialed in to fit your needs.
The resistor is an inexpensive way to quicker shifts, the VB mod is more expensive but permanent. The jury is still out on either one improving times, but both are said to help prolong tranny life. I read somewhere a thread from over a year ago where a very knowledgeable Nissan Tech (Mr. Martin) stated that the resistor was not recommended due to added strain on the drive system. I may be mistaken though.
TKHanson
11-24-2018 01:39 AM
REDinLV
10-18-2015 05:31 AM
tseng1023
10-15-2015 08:30 AM
