Synthetic Blend at 114K
Old Aug 8, 2002 | 02:22 PM
shatelb's Avatar
Hey I just changed over to sythetic blend at 114K and am considering changing to full sythetic by 130K. Has anyone experienced any problems with switching over? Any special oil filters or other stuff required?
Old Aug 8, 2002 | 09:25 PM
SunMax's Avatar
Re: Synthetic Blend at 114K
I don't think you will have any problem switching over. Just use Nissan filters.
Old Aug 9, 2002 | 05:20 AM
njmaxseltd's Avatar
Synthetic Blend? Which oil are you using? I hope it's not Castrol Syntec Synthetic Blend, because that is not very good oil.
Old Aug 9, 2002 | 07:59 AM
speedtrip's Avatar
I switched from dino oil to a full synthetic oil at 102,000 miles and have no problems to date. No leaks or oil burn-off.
Old Aug 9, 2002 | 08:03 AM
iwannabmw's Avatar
There shouldn't be any issue with going to a full syn at your next oil change. Many people with higher mileage have switched with no problems. The synthetic blends are a waste of money, not enough "synthetic" in them to justify the cost. If you want dino oil, buy that. If you want synthetic oil, buy that. The blends are just marketing hype.
Old Aug 10, 2002 | 08:26 AM
97blackv1's Avatar
Old Aug 10, 2002 | 11:34 AM
gsleve's Avatar
Re: Re: Synthetic Blend at 114K
Even amsoil is not technically a 100% synthetic they also use a petrolem component or "carrier oil" named infineum to carry the additive package within the oil. Although I concur with thought that blends are mostly marketing hype and no substantive value can be found I believe that schaffeurs stands out to be unique in this category and has to date proven itself worthy oil to look into it is a synthetic blend with characteristics for extending drain intervals
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
