Sounds after Brake Pad Replacement
Hi,
I changed four aftermarket brake pads for my 98 max. couple days ago. Now the brakes make a lot of sounds whenever my car is about to stop. Are all the aftermarket brake pads make sounds, and how can I fix it (noise free)?
UC
UC
Originally posted by uc147
It squeal and groan. I let the autoshop changed for me, and I saw there is a metal plate on each brake pad when the mechanic took the old brake pads out. He didn't put those metal plates on.
What happends if you changes your brakes your self and you did everything right? I only changed my fronts and the backs had alot left so i dident but now when i brake it squeeels and somtimes if i work the pedel right it dosent....any one know?
oh yea and i got my brake bads drom discount auto parts
-ChRi§
-ChRi§
-ChRi§
-ChRi§
silly question? how much brake dust do you have on your calipers.. once i had squeal noise once after changing my pads 2 weeks prior.. i was going to pull it down and check it.. but i went to the car wash first.. after i was done washing my car.. the noise was gone.. yes.. you heard it right.. too much brake dust can cause squeel noise.. i would check that first..
if that checks out.. and the shims are in.. sometimes its normal to get a little squeak every now and then.. just get some anti squeal compound from discount auto parts and squeeze it on the pads
Originally posted by SprintMax
did you put your shims back in?
when you say shims you mean that metal peace that looks like a taken aprt paper clip that attatchs to the both brake bads? if so then yes thats on...
wash your rims and calipers tommorow.. see if the sound goes away..
if not.. get some anti squeal compound its a gel like substance.. squeeze that in between the shims and pads
yeah thats them..
yeah thats them..
alright i will try cleaning them, but that gel cant i just sqeez it on the calipers and let it rub onto the bad as i brake, becuase taking of my bads agian is a *****... i hated changing my braks... oh yeah and does anyone know a way to get the back braks..the part that push the pads back in? for the front i just used a rench and squeezed as hard as i could and took out the extra brake fluid...for the back there is really not a good place to use that same tool... anyone know?
I think you can also buy a tool at an auto store that will fit on the rear brake piston. You have to turn it instead of pushing it back, different from the front brakes.
i used a needle nose pliers to turn the piston .. keep turning it and then the piston goes in and you can slide the caliper back down over the pads..
I changed my brakes 3 weeks ago. All four are brand new, however after I leave my car standing on the handbrake for a while and then start driving it sound like a groan from the rear. A shop changed the brakes for me. What can be the problem?
Forward.
Forward.
Re: Brake Pad brands?
Originally posted by oppaman
btw, which brand of aftermarket pads
would you recommend? Car & Driver (8/02)
had an informative article on aftermarket
brake kits. They used Hawk HP pads.
Which other ones are both good & durable?
RealityCheck
08-05-2015 06:18 AM
