Steering Tightness..please help me out.
I have a 1995 Max GLE, and scinse i got the car the streering has been very very loose, i was just curious if there was any was i could adjust the the steerint so that it could get any tighter, it scares the hell out of me when im gong fast.Just curious.
Originally posted by ny96max
he talking about all the play in the steering wheel without the car even turning. My 96 has alot of play in it, but i just learned to deal with it
Ant
Ant
OR,you can buy ES polyurethane bushings for the front sway bar, control arms, and endlinks. That drastically changes the feel of the wheel. It increases it's "weight." You'll get vibrations though, so it's a trade-off.
Yes ES bushing will help. Go to suspension.com. I got mine there. Don't forget to grease them or they will squeek.
Another thing to check is your aligment. To much toe out loose on center feel but better in turns. To much toe in better on center feel but the car will feel like it is plowing around curves.
Originally posted by TurDz
I guess you can learn to deal with it.
OR,
OR,
I just installed ES bushings with my AGX/B&G combo, and I noticed my steering felt slightly stiffer. I thought maybe something something was wrong, but now this makes total sense.
95maxrider,
Endlink are not so car specific. When I called Bruce (I think that was his name) knew what I wanted. Anyway I have the endlinks and swaybar bushing and would say that the are definity worth it.
The control arm bushing are where you get vibration transfer from the suspension to the steering wheel. How much on a max I do not know as I do not have them.
Chris
Chris
Originally posted by 95Max
95maxrider,
Chris
95maxrider,
Chris
I go mine a couple of years ago and both were under $20. As for neg....hummm...the only thing I can think of is that the swaybar bushing will squeek if you don't grease them. Make sure you use waterproof grease. Bushing should come with the grease. If you want extra get water proof trailer grease from a marine supply much cheaper then ES.
Originally posted by $tillen$ux
what are "ES" bushings? where do they go?
For the maxima there are:
- Front sway bar bushings
- endlink bushings (ends of the sway bar)
- Control arm bushings
DC_Juggernaut
Sep 28, 2015 04:07 PM
